What is this dohicky?
Old Jul 26, 2009 | 10:55 PM
flipklos's Avatar
flipklos
I just pulled my holley 2300 off my extra 292.
It has a large alumanum spacer underneth with an oval on the side sticking out about 2". There are a set of butterflies inside on a shaft that cannot be moved by finger pressure. On the rear of said spacer there are two 1/8" steel lines that were not attached to anything. The engine is from a 60 F550 grain truck. What is the dohicky for? Is it a second choke?
Old Jul 27, 2009 | 12:17 AM
Snowking's Avatar
Snowking
If I understand that right. This mystery set of butterflies is beneath the throttle butterflies and the intake.....
Old Jul 27, 2009 | 06:09 AM
flipklos's Avatar
flipklos
Yes sir.That is where she be.
Old Jul 27, 2009 | 08:45 AM
bigwin56f100's Avatar
bigwin56f100
Its a governor and the 2 lines went to the distributor on that style.
Kevin Bigwin
Old Jul 27, 2009 | 04:10 PM
flipklos's Avatar
flipklos
They governed it by limiting airflow? What if you need to increase throttle for a hard spot?
Old Jul 27, 2009 | 06:57 PM
Snowking's Avatar
Snowking
Prolly the same thing modern governed semis have to do today, start gearing down. I hated being governed.
Thats weird though, never heard of that.
Old Jul 27, 2009 | 10:10 PM
flipklos's Avatar
flipklos
Usualy a governer on a truck with a pto is to hold an RPM. Same with a truck following a combine. It is all about a steady speed.
Links_vette
Sep 25, 2016 09:13 PM
BruteFord
Electrical Systems/Wiring
Apr 9, 2016 06:55 AM
Dalton Hatfield
1978 - 1996 Big Bronco
Jun 3, 2015 10:50 AM
Dutter
1983 - 2012 Ranger & B-Series
18
Nov 23, 2011 10:08 PM
ravens fan
18
Feb 23, 2011 05:46 AM
