new computer made things worse
Old Jul 25, 2009 | 08:01 AM
EPNCSU2006's Avatar
EPNCSU2006
I just re-read my last post and the way I have that quote in there makes it look like I was referring to the first sentence with the quote. The "absolutely" response was directed towards the question regarding the ability of a computer to output both 2 and 3-digit codes, which for one computer, it absolutely cannot do.
Old Jul 25, 2009 | 10:21 AM
DBGrif91's Avatar
DBGrif91
Originally Posted by frankyford
I know for sure the TAD and TAB haven't been replaced yet(thanks EPNCSU2006), but how many more do I have other than the ones I posted so far. I've put so much on this truck I can't remember all the crap I've put on it, I'm losing track of all of it.
Then if you still have all the receipts from your purchases [and for warranty purposes I hope you do], I recommend going thru them and writing out a list of everything you've done so far- electrically. The best bet for tracking down an electrical problem is thru process of elimination.
And I'll look up the test procedures on the TAD and TAB for you in a few minutes.
Old Jul 25, 2009 | 10:27 AM
Conanski's Avatar
Conanski
Sorry, no change pulled codes on it. This what I got,
172= HEGO shows system always lean
33= EGR valve opening not detected ( new EGR and new EGR solenoid)
45=Thermactor air upstream during self- test
38 (could be 48 couldn't find 38)but 48 is Loss of IDM, leftside whatever an IDM is
53=TP circuit above max voltage
66-MAF sensor input below min voltage
32=EVP voltage below closed limit
Some of these codes I didn't get off the old computer and on the passenger side of the engine it alot hotter than the driver side and can still smell raw gas, so the cats may be getting to hot.
Was the engine fully warmed up when you pulled the codes? It should be. The codes that are of most concern here are the over/under voltage ones, the TP and MAF sesnors don't need to warm up and should report correctly immediately so you need ot determine if the ref voltage to these devices is correct. And since you changed the computer this points to a wiring problem.
Old Jul 25, 2009 | 10:29 AM
DBGrif91's Avatar
DBGrif91
Okay, I'm not seeing anything my manual about testing the TAD and TAB but maybe I just can't locate it in the book.
Anyway, since I missed your original post on your problems, what is it the truck is doing? [A link to the original post will be fine.]
frankyford's Avatar
frankyford
Yeah, I got the receipts. They don't warranty certain electrical parts, the PCM is lifetime warrantied through O'reillys. And thanks for looking that stuff up for me.
Old Jul 25, 2009 | 10:34 AM
frankyford's Avatar
frankyford
It's a long story, it acts like it won't go under light acceleration, but when you give it gas to the floor it goes. Pretty much stumbles under light acceleration.
Old Jul 25, 2009 | 10:48 AM
DBGrif91's Avatar
DBGrif91
Kind of like it's going to stall out? Has it ever stalled? This is interesting, as mine has the same problem when it gets warmed up...
After you've warmed the engine up, then pull into say, a gas station, shut it off, run in for a minute, then come back out and start it up, does the idle vary between high and low, kind of like you're repetitively stepping on and off the gas? If so, then we may have the same problem!
I'm yet to start working on mine but I've considered the possibility that it could be the servo, but I don't see anything in my manual about how to test it. If I'm not mistaken it is vacuum operated.
*Edit- It does give procedures for adjusting it tho, if you wanna try that.
Old Jul 25, 2009 | 10:52 AM
frankyford's Avatar
frankyford
No, mine doesn't stall and it'll start right back up after shut off. Mine backfires through the intake under light acceleration. What is the servo?
Old Jul 25, 2009 | 10:57 AM
DBGrif91's Avatar
DBGrif91
The servo is the throttle actuator. If you notice there's two cables attached to your throttle body- one from the pedal, and if you trace the other it leads to a circular box mounted by the brake booster. It's essentially what makes cruise control possible in conjunction with the TPS.
Old Jul 25, 2009 | 11:07 AM
frankyford's Avatar
frankyford
Yeah, my cruise doesn't work had it turn off under recall, I wonder if that could have anything to do with this. It was acting up before I had it disconnected, I wonder if it had gotten hot and maybe burned something up.
Old Jul 25, 2009 | 11:17 AM
DBGrif91's Avatar
DBGrif91
Possibly.
Anyway dude, sorry to split on you, but my wife and I are leaving on vacation now for 10 days. Hopefully some of my advice will lead you to the source of the problem.
Good luck.
Old Jul 25, 2009 | 11:19 AM
frankyford's Avatar
frankyford
Hey, I appreciate it, have fun on vacation and be careful
Old Jul 25, 2009 | 03:31 PM
  #28
PJF95's Avatar
PJF95
Go back to the basics!
You are throwing parts at it and that is a sure way to throw money away and walk away frustrated.
This sounds like it could be a grounding issue. Anytime you set THAT many codes there is obviously something screwy.
Go check your grounds. You need good solid non corroded grounds. Ground problems can cause a huge myriad of problems exactly like you are describing.
Old Jul 25, 2009 | 04:53 PM
  #29
frankyford's Avatar
frankyford
I think I've narrowed it down to the MAF sensor. I've looking up alot of stuff on the internet and the symptoms it causes and they sound like the ones I'm having. I just sprayed it with electrical cleaner, but it didn't work. I guess I'll have to buy one and put it on.
4tl8ford
Dec 4, 2014 05:52 PM
RBassham
Feb 11, 2011 01:53 AM
Gottaford
15
Feb 8, 2011 02:29 AM
oppy
Jun 19, 2003 11:30 AM
tobins
Computer Chips & Tuners
Oct 31, 2001 01:36 PM
