could this happen
Old Jul 25, 2009 | 01:19 PM
frankyford's Avatar
frankyford
could this happen
Could a voltage regulator be bad and the alternator still be good if the voltage regulator is in the alternator. Those of you who don't know what truck I'm refering to, it's my 95 F-150 302 auto. I had my alternator tested and it came out good, but I can't remember if the voltage regulator was good or if it was even tested. Does this make any sense?
Old Jul 25, 2009 | 05:08 PM
Conanski's Avatar
Conanski
Yes that's possible, the benchtop testers at autoparts stores are notoriously unreliable when it comes to testing the internal regulator and rectifier in these alternators, I have seen this myself with my truck when it had a charging problem. Bottom line is you should measure 12.5v across the battery when the engine is off and at least 13.5v when the engine is running, if you don't get that then the internal regulator is bad.
Old Jul 25, 2009 | 05:11 PM
frankyford's Avatar
frankyford
I was just shooting in the dark, I thought that might be part of my low voltage to the MAF sensor. Probably just a stupid thought.
bigred66
Oct 1, 2012 07:21 PM
radmacks
Mar 1, 2011 08:38 PM
josh390
18
Nov 8, 2008 04:03 PM
madmader
Feb 26, 2008 05:34 PM
cubster
1983 - 2012 Ranger & B-Series
Oct 11, 2001 10:35 PM
