Sponsored by: Real Truck
Shackle flip?? Height gain?
Old Jul 22, 2009 | 09:25 PM
dsl_pwrd_ford's Avatar
dsl_pwrd_ford
I know its big on jeeps. But can it be done on superdutys? I have a 4" lift already but the front sits a little too low. Will this raise it up? Even if its an inch. The only thing I want to spend, is my time.
Anyone have a how to?
Old Jul 23, 2009 | 05:06 PM
dsl_pwrd_ford
anyone????
Old Jul 23, 2009 | 05:17 PM
Destroya's Avatar
Destroya
http://www.sky-manufacturing.com/new...uct.php?id=186
I never thought about doing this, sounds like a project.
EDIT:!!! That site is awesome, they have 2" and 4.5" shackle lifts. I think I'm going to order the 4.5" shackle lift to add to my current 4" suspension lift.
THANKS FOR THE IDEA!!!!!
Old Jul 24, 2009 | 07:45 AM
dsl_pwrd_ford
4.5" shackles might be taxing the limit of some of the steering components, lines and etc.
I just wonder if I can flip the stock ones and gain 1 to 2 inches???
Old Jul 24, 2009 | 08:15 AM
sphinx's Avatar
sphinx
I did it on my 93' and gained 2.5 inches. If I remember right. I was goining to do it to my 99' but ran across a set of factory dodge 1 ton blocks which are the height I was looking for.
Old Jul 24, 2009 | 08:47 AM
Mustang6147's Avatar
Mustang6147
Off the top of my head, I would think it would play a negative part in pinion angle, causing premature wear on the U-joints and possiblly bearings in the rear end and tranny or transfer case.
Unless you cut and reweld the mount plate on the axle.
Dont know, never tried it, because of reasons stated
Old Jul 24, 2009 | 08:53 AM
brian42's Avatar
brian42
Veteran: Navy
Am I just being a newb and missing something? The springs already sit on top of the axles (and a block spacer in the back too), or do you change the spring mounts to the frame?
Old Jul 24, 2009 | 09:40 AM
dsl_pwrd_ford
R u talking about flipping the stock ones or those lifted ones from above
Old Jul 24, 2009 | 09:52 AM
enduro4231's Avatar
enduro4231
You cannot flip the front shackles. Only the rears. This is because of 2 things; First, the design of the shackles themselves does not allow them to be flipped, the front shackles are 'boxed' at the axle end in a way and would not work upside down, and Second, the shackles mount directly to the frame, thus flipping them would only make them flipped, it would not gain you any height. Shackle flips are typically only done on the rears of vehicles because the pivot system that the rear shackles use allows height to be gained and more shackle movement to be gained when the design is flipped upside down. On our trucks, doing so in the front would have no effect unless the new shackles were longer. But they still would not need to be flipped.
When someone talks about a shackle flip giving them more lift height, it isn't actually the shackle being flipped that gained them the height. It is the pivot system as a whole.
Old Jul 24, 2009 | 02:43 PM
04redstroker's Avatar
04redstroker
There are kits that raise the front 2.5 and some that raise it 4.5in. i plan on adding the 4.5 to my 8in when my tires get bald and run some 44s.its not so much as a shackle flip as a hanger kit.
leveling: http://www.sky-manufacturing.com/new...uct.php?id=165
4.5in front: http://www.sky-manufacturing.com/new...uct.php?id=225
The 4.5 would take you past level but is an easy way to add afew more inshes to your truck. My buddy put the leveling kit on his stock 01 and really likes it.
Old Jul 24, 2009 | 02:59 PM
enduro4231's Avatar
enduro4231
I have done a shackle leveling kit to my truck that I fabricated myself.
For clarification purposes, the kits you showed are not actually shackle flip kits. They simply provide longer shackles and drop spring hangers to increase the distance between axle and frame providing more lift.
Old Jul 25, 2009 | 10:16 PM
04redstroker
[quote=04redstroker;7754889]i ts not so much a shackle flip as a hanger kit.
quote]
Thats what i said, just left out the word longer.lol
Catmonkey
2004 - 2008 F150
19
Mar 9, 2009 11:55 AM
kupiec20
17
Feb 3, 2009 09:46 AM
King0581
16
Apr 15, 2008 07:34 PM
marilyn
Jun 27, 2005 06:34 AM
