Factory Subwoofer
Old Feb 7, 2009 | 09:38 AM
Catmonkey's Avatar
Catmonkey
Factory Subwoofer
Where is this located in 2008 model? I know I have it, but I have no idea where to find it.
Old Feb 7, 2009 | 09:48 AM
andrmorr's Avatar
andrmorr
Black plastic box under your back seat on the drivers side...
Old Feb 7, 2009 | 10:14 AM
Catmonkey's Avatar
Catmonkey
I don't see a plastic box under the rear seat. Is it behind the rear seat or under the carpet?
Old Feb 7, 2009 | 11:31 AM
pb34's Avatar
pb34
It should just be right under the seat. It's hard to miss.
Old Feb 7, 2009 | 11:40 AM
Catmonkey's Avatar
Catmonkey
I suspect it's under the carpet because there isn't much room between the carpet and the bottom of the seat. Anyone know the size of the speaker?
Old Feb 7, 2009 | 11:44 AM
pb34's Avatar
pb34
I know for sure in some of the 04-08 models that the subwoofer is not under the carpet. I've never heard of one being under the carpet. Are you sure you have it?
Old Feb 7, 2009 | 11:46 AM
Catmonkey's Avatar
Catmonkey
I know I have the Audiophile sound system. I don't know as an absolute that I have the subwoofer and the reason I was inquiring as to its location. Doesn't the Audiophile come with the sub?
Old Feb 7, 2009 | 12:01 PM
Catmonkey's Avatar
Catmonkey
Well I thought Premium sound system was the Audiophile, but I must be mistaken. Bummer
Old Feb 7, 2009 | 12:10 PM
SteveVFX4's Avatar
SteveVFX4
under the carpet? LOL, That is funny man!!!
Clearly if you don't have this big black box under your rear seat, then you don't have the audiophile system:
Old Feb 7, 2009 | 12:21 PM
Catmonkey's Avatar
Catmonkey
OK, OK, I'm learning. Now that I see it, I can see the humor in my question. But not having seen one...... No, I don't have it. I'm not real sad about it because I was going to change the door speakers anyway. But I would like a subwoofer.
Does anyone know if the premium sound system w/6 CD changer and satellite radio would have the plug to install the factory subwoofer, or is it a different head unit altogether?
Old Feb 7, 2009 | 01:30 PM
BluByu1986's Avatar
BluByu1986
The premium audiophile system has 3 plug-in's in the back of the deck. If you deck only has two plug-in's then it's not the audiophile unit.
Mine was the plane jane unit and I upgraded to a Shaker 500 unit out of a mustang...... And bought the factory sub off ebay for $100
Old Feb 7, 2009 | 01:58 PM
SteveVFX4's Avatar
SteveVFX4
yeah you need the Audiophile head unit with 3 plug-ins. Yours probably has 2 plugs. The 3rd plug is usually in the dash taped to the main radio harness, you should find it if you take your radio out and look back there.
as far as the sub/amp, you have to have the plug under your back seat. In that picture I posted, on the rear driver's side, look behind that black seat bracket and look for a slit in the carpet on the floor. reach in that slit and see if you find a harness plug. If yes, then that's for the sub/amp. Most Lariat's seem to have the plug under there so there's good chance yours does. My FX4 did not so I went with an aftermarket sub/amp setup.
Old Feb 7, 2009 | 02:12 PM
Catmonkey's Avatar
Catmonkey
I found the slit in the carpet, but I don't feel a plug. I lifted up the panel on the rear door and there are a lot of wires running to the rear of the cab. I'll fish around in there tomorrow. Thanks for the help.
Old Feb 7, 2009 | 02:21 PM
SteveVFX4's Avatar
SteveVFX4
there's a computer module mounted on the back of the cab wall back there called the body control module (BCM), so alot of those wires are probably for that. Make sure you reach in that slit as far as you can (towards the cab wall), sometimes the sub harness might be tied back in there.
Old Feb 7, 2009 | 02:48 PM
BluByu1986's Avatar
BluByu1986
I've got a '05 FX4 and the plug for the sub was in my truck. You just have to feel around in that slit in the back seat. The plug that's in the dash is taped up and you can't miss it when you pull the factory deck out.
Good luck,
