Engine coolant
Old Apr 11, 2008 | 07:38 PM
King0581's Avatar
King0581
Engine coolant
Its about time to change mine and I have the gold stuff. Whats best to run with it?
Old Apr 12, 2008 | 10:27 AM
King0581's Avatar
King0581
Any suggestions on what to replace it with?
Old Apr 12, 2008 | 10:36 AM
F350-6's Avatar
F350-6
I just used the gold stuff again. I don't mind changing it every 100k. There is a new (red I think) one that's supposed to be good for 300k if changing it every 100 is too much.
Old Apr 12, 2008 | 10:56 AM
big poppa's Avatar
big poppa
Hey chris, i got to change mine too soon, can you get the red stuff at ford dealer or is it in stores.
Old Apr 12, 2008 | 10:58 AM
Izzy351's Avatar
Izzy351
Gold is a good compromise between the ELC and Green. It has some silicates, but they do not need checked & maintained like the old green. You can go with the ELC as well, but it's a little more expensive and requires good flush before hand. Your choice.
Old Apr 12, 2008 | 11:18 AM
jwhitetail's Avatar
jwhitetail
Evans NPG is the best, never change it again and it has so many benefit's.
Old Apr 12, 2008 | 11:21 AM
F350-6's Avatar
F350-6
It's available in stores. It's the ELC Joe was talking about. Maybe he can tell you where he got his.
Old Apr 12, 2008 | 11:33 AM
big poppa's Avatar
big poppa
I got the gold. But I'll check around and see if anybody got the ELC, i really don't mind changing mine either but i'll check it out, thanks. Hey joe, long time no here.
Old Apr 12, 2008 | 03:49 PM
Izzy351's Avatar
Izzy351
Check with Napa -- they should have it. Ask for Final Charge in concentrate -- it's the same as Rotella ELC. You'll need four gallons of that and about 20 gallons of distilled to flush out the old stuff. Save enough of distilled after flushing to top off after dumping the four gallons of ELC in (about 2-3 gallons).
Old Apr 12, 2008 | 04:07 PM
King0581's Avatar
King0581
I was thinking of going with the Rotella if I can find it locally. So will I need to do a good flush to use it also?
Old Apr 12, 2008 | 04:14 PM
Izzy351's Avatar
Izzy351
Just drain, fill with distilled, heat up to temp so 'stat opens, let cool, and repeat until you get down to 3 gallons of distilled left or the water coming out is perfectly clear. That should get it clean enough to add the ELC.
Also, you can get the 203* stat and pull the old one out first to speed up the flush process. You won't have to wait for the engine to heat up between cycles. Put the new stat back in on the last drain and you should be good to go. You can also drain the block in the back if you like, but some folks have had equally good results without going though that.
Old Apr 12, 2008 | 04:17 PM
King0581's Avatar
King0581
I have heard about the 203 thermostat before. Does it fit into the stock housing or do you have to by a new one?
Old Apr 12, 2008 | 04:19 PM
Izzy351's Avatar
Izzy351
You can reuse the stock housing if it's in good shape. If not, get the billet one from DieselSite.com when you order the stat. As long as you get the long stem stat, it's a direct replacement. DieselSite will send you the right one.
Old Apr 12, 2008 | 04:23 PM
King0581's Avatar
King0581
Thanks for the help! I'm gona be checking out the site today to order it.
Old Apr 12, 2008 | 07:42 PM
big poppa's Avatar
big poppa
Thanks joe.
