Ford Wheel Center Caps
Old Jul 22, 2009 | 02:05 AM
JRB65's Avatar
JRB65
I found out today that I have a set of Ford Wheels on my pickup that fit 90-96 2wd F150's. I have been looking for a set of caps for the center of the rims and found them on EBAY. Right now I have a bid in for $70 for a set of four and hope the bidding doesn't go up much more. But considering if I bought them through the Ford Dealer they would cost $66 a piece, Im not doing to bad. If anyone has any of these laying around wanting to part with them let me know. I have found someone in Canada on the 87-96 Fords but I bet the shipping from Northeast Canada will be huge.
JRB65
Old Jul 22, 2009 | 02:48 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
You found them on ebay? How do you know they're correct?
There are...at least TWELVE different types of hubcaps! Some are 4WD only.
And...there was a similar looking wheel that was used 1977/79, another used thru the 1980's.
Then there's this: Rangers/Bronco II's used similar wheels. The hubcaps used on Rangers and Bronco II's look the same, and may be the same, but...
In most cases they are not the same. How many peeps know one type of hubcap from another?
Note: FTE has Ford Dealer Parts Department sponsors that give discounts to members off the actual MSRP.
One is y2kfordparts.com aka MILLENNIUM FORD in Seattle.
Here are the wheels...from lookin' at the pic you posted, your wheels appear to be the type w/o rivets.
FOTZ1007A .. Styled Aluminum Deep Dish Wheel / 10 Openings with Rivets.
F4TZ1007B .. Styled Aluminum Deep Dish Wheel / 10 Openings w/o Rivets.
Here's the hubcap. They are not $66.00 each! If some dealer gave you that price...it's for the wrong hubcap, or they are selling them to you below dealer net.
E2TZ1130C.. Ornament (Hubcap) Chrome w/Red Center / 7 1/8" diameter / Use with deep dish aluminum wheel.
Fits: 1982/94: F150 / E150 / U150 - Rear Only.
MSRP each: $105.30 // y2kfordparts.com price each: $75.82.
btw: How do you plan on installing these caps on the wheels? They do not snap on.
Old Jul 22, 2009 | 03:55 AM
NumberDummy
I couldn't add this to the post above, as I ran out of editing time.
The E2TZ1130C hubcap has an ID number marked on it: (ED) E2TA-1A096-SA
I hope those ebay caps have this same ID number, otherwise....
Old Jul 22, 2009 | 10:58 AM
JRB65's Avatar
JRB65
NumberDummy,
Again your saving my Bacon!!! Thanks for your insight on this and your info. There are three places for screws to be installed to hold the center cap on. I also knew about the 4wheel drive part, on the caps for 4X4's the front hub is open to allow for the hub. On the 2WD, all the caps are the same. The set I am looking at on EBAY are all the same and off a mid 90's F150. My rims are the ones without the rivets also.
Thanks,
JRB65
Old Jul 22, 2009 | 11:44 AM
JRB65's Avatar
JRB65
NumberDummy,
I retracted my bid on EBAY. Thanks again for the info.
JRB65
JRB65
Mar 11, 2013 12:16 PM
JRB65
24
Feb 5, 2013 09:05 AM
JRB65
Dec 29, 2012 08:11 PM
JRB65
Dec 22, 2012 05:31 PM
JRB65
23
Dec 12, 2012 10:27 AM
