Oil & Lubrication
grease zerk on upper balljoint
Old Nov 3, 2002 | 02:02 PM
PigFarmer's Avatar
PigFarmer
I replaced the balljoints on my '89 F150 4X4. After getting everything back together I went to pump everything up with grease. Only then did I realize that the zerk on the upper balljoint cannot be accessed straight on with a grease gun. I shoulda put right angle zerks here. Don't want to tear everything apart so does anybody have a slick way of greasing these zerks. I have about 1/2" clearance between the top of the zerk and the spindle knuckle. I need a very low profile right angle grease gun tip or a right angle needle tip. Don't know if these are made this tight tho.
Old Nov 21, 2002 | 06:12 PM
rgiles's Avatar
rgiles
Did you ever find a solution or did you end up tearing it back apart?
Old Nov 21, 2002 | 08:22 PM
1984_355w's Avatar
1984_355w
I had the same problem on my '84. I put on a 45 degree zerk aimed strait ahead and it works great!
Old Nov 22, 2002 | 08:31 AM
PigFarmer's Avatar
PigFarmer
Thanks for the reply. I haven't solved the grease zerk problem yet. Kinda put it on the back burner as the truck is still in my shop with the motor out. The angled zerk would probably work if I can find one low enough profile. I was also thinking of custom bending a needle to hit these if I can get the needle bent without collapsing it altogether. Wish I woulda noticed the problem before I put everything back together!
Old Dec 9, 2002 | 10:06 PM
rebocardo's Avatar
rebocardo
In case you have not solved this yet, NAPA sells grease adapters that push on straight. You need only about 3/8 clearance. We use to use them for the occasional FWD Chrylser that came in the shop.
Old Dec 9, 2002 | 10:36 PM
PigFarmer's Avatar
PigFarmer
Ahaa!! I knew someone here would come thru with a simple solution. I'll check those out. Thanks Rebocardo!!
Randy
Old Dec 22, 2002 | 03:41 PM
PigFarmer's Avatar
PigFarmer
I picked up that grease gun fitting yesterday at NAPA. It is made by Thextron. This is PERFECT for greasing the lower balljoints (or any other tight quarters zerks for that matter). Only takes up about 1/4" and slides on at a 90deg. angle to the zerk. Everyone should have one of these in their toolbox. Thanks again Rebocardo!!
Randy
Old Dec 22, 2002 | 08:45 PM
rgiles's Avatar
rgiles
JohnnyAirtime
Apr 14, 2016 05:43 PM
351Cleveland C4
Aug 11, 2014 02:44 PM
ZeroTucker
May 15, 2011 07:54 PM
wildcat99
Sep 26, 2007 09:47 PM
Gearheadjo
Nov 16, 2006 06:12 PM
