Quality T-stat ?????????
Old Jul 24, 2009 | 12:03 PM
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
Exclamation
Originally Posted by strokin'_tatsch
. my water neck leaks a tinyyy bit. like haven't added any to it in 2 years and you can see it leaks a little. LoL.
Originally Posted by DZL JIM
Rocky,
Generally, from what I have run into, the water neck doesn't leak until you mess with it.
Well, my water neck also leaks a tiny bit, and never had messed with it, and also I havent added any coolant in more than 2 years; but Jim make me think and Im going to check the water pump pulley as mentioned.
Old Jul 24, 2009 | 01:32 PM
DZL JIM's Avatar
DZL JIM
PREMIUM SPONSOR
The only 203* stat for '96 - '03 is from Dieselsite.
The '94 - '95 (or somewhere in '95) had the short stat that you can get a 203* stat for from parts store.
On my Black Truck I installed an IH waterpump with integral filter. That pump uses the short 203* stat for the earlier pumps.
Originally Posted by barebackjake
just use grey rtv on the stupid tstat housings and let it sit overnight. ive had the one in my truck for 5 years or so now and it still works great.
This will be the forth time in 4 months I have had to have it off. I hate dealing with silicone each time, so I will try a new neck.
__________________
'96 7.3 F-350 Reg Cab 4x4 - bought new.
'04 6.0 E-350 custom 4x4
'08 6.4 F-550 Reg Cab 6 spd 4x4
'17 6.7 F-250 KR ccsb 4x4
Old Aug 6, 2009 | 10:21 AM
notiones's Avatar
notiones
Good thread. I just ordered a t-stat and neck from dieselsite. Mine appears to be stuck open as temps are low and mileage is down.
Old Aug 6, 2009 | 12:03 PM
DRRXR's Avatar
DRRXR
Test
I would test the old one to make sure that thats the issue. Fouled or even bad injectors can cause lower temps and higher fuel consumption.
Old Aug 6, 2009 | 01:01 PM
notiones's Avatar
notiones
At 146K the truck still runs great and even though I just bought it at 130K, I have always run diesel kleen and purchased my fuel from recommended distributors. I also had about $4k worth of work done by a diesel specialty shop when I first got it. Mostly stuff like breaks, new water pump, hoses and the like, but they said the motor was in great shape. If mileage doesn't improve after replacing the t-stat, I will look into the injectors though. Right now I am averaging 16.5 in mixed driving, which is down from about 18-19 mixed and 22 on the highway.
Old Aug 6, 2009 | 05:18 PM
DZL JIM's Avatar
DZL JIM
PREMIUM SPONSOR
Steve,
I have not noticed any increase in mileage with a new, hotter t-stat.
So far teh 203* stat is working fine. Hope that lasts.
Your mpg sounds about average to me, but if you were seeing higher I'd bet that might have been with the 'old' fuel. I noticed quite a drop with the new ULSD fuel about 1.5 years ago. I used to get 19 - 20 and now get 17 - 18.
Also, I'll bet your injectors could use at min. some fresh o-rings. Totally doable by you in a few hours if you want. If they still have the originals in there, I'll bet there's not much left of them by now.
...And clean your FPR screen, too, when you do injector o-rings.
__________________
fordboy2
Dec 17, 2014 06:55 PM
MattP51
22
Mar 7, 2009 04:18 PM
DZL JIM
Feb 28, 2009 09:13 AM
glu252
Oct 4, 2004 05:45 PM
Faithful Old Road Dog
Jan 10, 2004 12:21 AM
