Quality T-stat ?????????
Old Jul 21, 2009 | 06:19 AM
DZL JIM's Avatar
DZL JIM
PREMIUM SPONSOR
So the original on my '97 went sometime last winter. I finally get to put a new A-zone stat in last April. It lasted 2 days...
A month goes by I finally get to put a new NAPA stat in, it lasts 2 months...
These hang open and truck never warms up.
So I'm sick of this ***** now, do I just get one from Ford or IH, or are there good aftermarket stats?
Thanks.
__________________
'96 7.3 F-350 Reg Cab 4x4 - bought new.
'04 6.0 E-350 custom 4x4
'08 6.4 F-550 Reg Cab 6 spd 4x4
'17 6.7 F-250 KR ccsb 4x4
Old Jul 21, 2009 | 06:44 AM
Cuda_jim's Avatar
Cuda_jim
Jim, I have the 203 stat from the 'other' site. HERE
It's been about 2 years and all is well. It may even add a little power to the engine....I didn't really notice any. The extra cab heat is nice, seems to warm up faster too.
Oh, be sure to get a new water neck...HERE the old one probably won;t seal...they rust out too.
Old Jul 21, 2009 | 06:49 AM
MADVAN's Avatar
MADVAN
"Quality T-stat ?????????"
No such thing as this Jim!
They all fail in the same way as you have stated.
Have the same issues with the 203* The 203 seems
ok until it goes thru a summer season. Than same old chit starts again.
I have had the best luck with the IH stat. Its a Behr Thomson, german
made. It has a rubber seal on the stat that helps with the restriction
closed. But they also are hit and miss until you get a good one.
They are the expensive!
Bill
Old Jul 21, 2009 | 08:34 AM
Action4478's Avatar
Action4478
Bill
Did you ever finish the 210 mod ?...
Old Jul 21, 2009 | 09:03 AM
DZL JIM's Avatar
DZL JIM
PREMIUM SPONSOR
I noticed in my extra parts box that an old IH stat (my '97 wasn't original) had that rubber seal. I'm thinking it's going to be IH this time. Last time I checked they were around $70 I think? It'll be worth it if it lasts. If...
I know about the 203 from riley, I have an IH 203 in my Black truck and never really noticed any difference. I don't know, maybe his is worth a shot this time...
I know all about the water necks, too, nothing to do with rusty, they are just flimsy. Getting tired of siliconing that stupid thing on there, but new ones aren't any better. I thought of making my own with a 1/4" plate on the bottom to be done with it.
__________________
Old Jul 21, 2009 | 09:04 AM
wildstang's Avatar
wildstang
VT Chapter Ldr
I also installed the 203 that cuda linked to late last summer. So far seems to work good, maybe 5000-7000 miles on it. Nice to have the heat especially during the Vermont winters. I did not replace the water neck and it sealed good for me, I haven't seen any leaks.
Is your coolant clean, if not maybe that is what is causing them to gum up, just a thought.
Old Jul 21, 2009 | 09:08 AM
DZL JIM's Avatar
DZL JIM
PREMIUM SPONSOR
Good thought on the coolant, but it's all new coolant when I replaced the water pump and all the hoses, just after the NAPA stat went in, like a week later. Seriously.
Maybe I need to look at adding a coolant filter. I did that on one of my older trucks, just to be safe...
__________________
Old Jul 21, 2009 | 07:41 PM
pjwoolw's Avatar
pjwoolw
The Motorcraft / Ford T-stat comes with the o-ring / gasket installed on the stat. I got allen head bolts to replace what was there and a new housing / neck. No issues. What was in there was the Behr-t. Had a piece of silicon stuck in it.
Old Jul 22, 2009 | 06:39 AM
MADVAN's Avatar
MADVAN
Worked well. Problem is its based off the oem chit.
Started working on a temp/flow adjustable electronic version t-stat.
Just have not had the time. The pita is choking off the bypass in the pump
to where iam happy with it. (lenght vs stroke issues)
Bill
Old Jul 22, 2009 | 08:18 AM
strokin'_tatsch's Avatar
strokin'_tatsch
i have had the same t-stat from o-rielys for 2 years now. it gets warmed up quick and doesn't over heat in stop and go traffic for an hour and a half so i guess it's doing a great job so far. my water neck leaks a tinyyy bit. like haven't added any to it in 2 years and you can see it leaks a little. LoL.
Old Jul 22, 2009 | 04:27 PM
DZL JIM's Avatar
DZL JIM
PREMIUM SPONSOR
Well I went ahead and ordered the stat and neck from Riley. Figured I'd rather put some $$$ in his pocket than Ford or IH, we'll see if it holds up...
__________________
Old Jul 23, 2009 | 09:10 AM
DRRXR's Avatar
DRRXR
Noticed this thread and thought to drop a line. Came home last night and saw coolant running out. I cant see where its coming from yet. Anyhow I disconnected the resourvor and plugged the hose. When the truck cooled down the flow almost stopped. I think its the water pump but i was wonder about his flimsy neck thing. Anyhow I will start pulling it apart and see what i find. Then I will drain the rest.
Rocky
Old Jul 23, 2009 | 10:04 AM
DZL JIM's Avatar
DZL JIM
PREMIUM SPONSOR
Rocky,
Pull your serp belt off and grab the water pump pulley. Give it a few tugs here and there. If there's any slop, you need a new pump.
When I replaced mine due to water leaking, I couldn't beleive how sloppy that pulley was, wonder how the thing even worked.
Generally, from what I have run into, the water neck doesn't leak until you mess with it.
__________________
Old Jul 24, 2009 | 11:09 AM
DRRXR's Avatar
DRRXR
I need smaller arms
Originally Posted by DZL JIM
Rocky,
I almost cut the top out of that darn fan shroud. Its a killer on the forearms. Anyhow the pully was fine, the seal just crapped out. Got er done.
A while back my wife was driving this on a trip and the fan belt died. I think that the darn fools put it on wrong as it was loose as a goose. I think they had it bassackwards on the cam and pump. Not sure, but I need to restudy if the way Ithink they had it would have still worked. I got it on right and there is hardly any slack. Before the change out, the dang belt kept slipping when I was pulling the belt guide (pully) off the pump.
I tried to find the IH 203 deg. F around here but could not fined it. I think I will order one if thats what the group thinks is the way to go. It should not be to hard to get the bolts back off and all seeing as I just did the pull adn install. My fluid looked and tested good. I took it to a buddy of mine at work, anyhow I ran it through a Tee shirt anf put it back inthere. Its the Texaco Red Fluid 500 K mile rated stuff. Hi dollar but looks good.
Old Jul 24, 2009 | 12:00 PM
barebackjake's Avatar
barebackjake
i run the 203's from dieselsite in both my trucks. just use grey rtv on the stupid tstat housings and let it sit overnight. ive had the one in my truck for 5 years or so now and it still works great. although i am about to get a new coolant gauge the cyberdyne coolant temp gauge i have is screwing up. bout to order a spa digital for it.
