Sponsored by: Real Truck
ECM or BCM?
Old Jul 20, 2009 | 07:46 PM
1ford1's Avatar
1ford1
ECM or BCM?
I was told I needed a new ECM. I have noticed the part numbers I have are listed for a BCM (Body Control Module). The part number is xc3f-12a650-ayb. The part number for the ECM is listed as MTC-101. These numbers are on the Autzone website. The truck is a 99 F250 SD, V10, 4x4. Also, the xc3f-12a650-ayb is located behind the emergency brake and kick panel. Is this the ECM?
Old Jul 20, 2009 | 08:26 PM
F350-6's Avatar
F350-6
The ECM (electronic control module) or PCM (powertrain control module) is the truck computer located behind the e-brake pedal on the drivers side kick panel. I have no idea what a BCM is, or what part of the Body needs to be controlled by a module.
Nothing against Autozone, but I'm not sure if I'd trust them for a computer. If you go that route, be sure to let us know how it works.
Old Jul 20, 2009 | 09:23 PM
1ford1's Avatar
1ford1
Thanks for the reply. I do not trust Autozone, just using them for references. I am not sure where to buy an ECM. Ford wants $475 for one. I am planing to use a preowned ECM to verify that it is the ECM. Are the ECM's vehicle specific or are they V10 specific? Will one out of a E250 work?
Old Jul 20, 2009 | 09:27 PM
F350-6's Avatar
F350-6
Sorry, I'm not familiar enough with the gas motors. I'd guess you need to make sure it's V-10 specific, and if there were any changes in the motor over the years, you'll need the correct "family". Hopefully someone with more knowledge on the gas motors comes along and can offer better advice.
Old Jul 20, 2009 | 09:28 PM
1ford1's Avatar
1ford1
What would be a good shop manual for a 99 F250 SD?
Old Jul 20, 2009 | 09:39 PM
F350-6's Avatar
F350-6
Check alldatadiy who is a sponser here. They'll give you access to the same info the Ford techs have for around $30 / year if I remember right.
Old Jul 20, 2009 | 09:46 PM
1ford1's Avatar
1ford1
Thank you for the replies
mrfix71
Jun 4, 2018 10:16 AM
mattmattf14
May 1, 2017 10:22 PM
GuitarJesus
Ford Truck Parts for Sale
Apr 27, 2016 02:34 PM
kennyr
Jul 9, 2011 11:25 PM
Tronick
1978 - 1996 Big Bronco
Jun 19, 2003 08:55 AM
