Hood Adjustment
Old Jul 21, 2009 | 10:03 PM
Bullitt390's Avatar
Bullitt390
Certified Thread Hijacker
I was in the same boat, I installed different inner fenders and radiator support.
Josh
Old Jul 22, 2009 | 08:16 AM
Poison Oil Racing's Avatar
Poison Oil Racing
Originally Posted by Bullitt390
To bring the back of the hood down, you actually adjust the hood to open MORE. Seems counter- intuitive, but adjust the hinges to tilt the hood back (or open more) and when the hood closes it collapses more of the hinge bringing the back down more.
I still have to play with that on my truck, I hate adjusting hoods. Then doors... then tailgates... then...
Josh
I will try this today. Thanks
Old Jul 23, 2009 | 01:10 AM
78_f800crewcab4x4's Avatar
78_f800crewcab4x4
Originally Posted by Poison Oil Racing
Tell me about it. I have decent spacing at the front and at the cowl, BUT, the hood will not sit all the way down at the cowl. Sticks up about 1/4 ~ 3/8 of an inch.
Any ideas are appreciated.
Mark
Hood sits higher than the cowl?
try opening the hood, loostening the [3] lower bolts between the inner fender and the hinge. shift the forward end of the hinge UP, leaving the rearward end all of the way DOWN. this forces the hinge to rotate more fully when closing the hood, making your hood close all of the way, eliminating the misalignment.
I tested this theory on all 3 of my 73-79s, with excellent results.
Of course, dont over compensate, its possible to make the hood sit too low.
Usually one would try to adjust the hood hinge down all of the way in an attempt to get the hood down all of the way, this in incorrect.
Old Jul 23, 2009 | 07:47 AM
Furyus1's Avatar
Furyus1
I just noticed yesterday my truck has a gap between the hood and grill - I'd say about 3/4" or so... Never noticed it before because I have a bug shield mounted to the hood and the bug shield is flush with the grill when the hood is closed... If the hood had been flush with the grill, the mounting tabs for the bug shield would've dented the grill surround so, in my case, it was good to have the gap lol...
Old Jul 23, 2009 | 07:53 AM
Diesel_Brad's Avatar
Diesel_Brad
i tried that. Then i loosened the 3 bolts that bolt the inner fender bracket to the fender cab,and slid them down. That helped alot but the hood is still high, by about 3/8-1/2" It will go down flush but you have to push it down,guess the spring tension is holding it a touch
Old Jul 23, 2009 | 09:42 AM
bucks77ford's Avatar
bucks77ford
Originally Posted by Diesel_Brad
Yeah. I was going to try to split the gap between the cowl and the grill. What a PITA putting this truck back together. There is so much adjustments on every bolt but not the way you need it. And it sucks , cuz i had every nut,bolt,bracket off and this is an entirly different cab to boot
I hear ya there. These trucks aren't perfect by any means. I seems like I've put endless time trying to get things lined up only to find myself back where I started. When you have one gap or line looking good, it is off at another place. I've managed to get things lined up decent and called it good. As long as things shut nice and look OK that's about all you can do. When these trucks were built, appearance was not something that was 100%. Like what was said already, every truck will look just a little different.
Old Jul 23, 2009 | 09:05 PM
Poison Oil Racing
Well, I adjusted the hinges as mentioned above and the hood shuts just fine and is all lined up. Never would have thought that forcing the hinges to open more would shut the hood!
Thanks for the help.
Mark
Old Jul 24, 2009 | 02:11 AM
78_f800crewcab4x4
its possible your hinges are simply worn out. also try spray lubricant. my new hinges had this problem after i had them chromed (baked all the lube away), they made the hood sit an inch higher than the cowl. i lubed em up good and they work fine now. lowering the whole front clip in relation to the cab and doors only creates other problems. a way of doing the procedure is to loosen all of the above mentioned bolts, then lift the hood open as far as it can go, until the hinge rotates/slides up in the front, with all of the weight supported by one back bolt on each side, then tighten before letting go. its as best as i can explain.
Old Aug 14, 2009 | 01:30 AM
Furyus1's Avatar
Furyus1
OK, I've just spent several hours fighting with this... I finally got around to swapping out the hood latch with the locking latch out of my Econoline and noticed the hood was out of whack...
Problem is: I can get one side lined up perfectly, but the other side will be out of alignment. I can't seem to get both sides to line up with the cowl evenly at the same time. And, to top it all off, the forward edge of the hood doesn't want to be level - the right side wants to sit higher than the left for some odd reason.
I finally got it to where I just said "to hell with it, it's close enough" and called it a night but I think the hood itself might be twisted or warped or something - either that or all the other panels on the front end are out of whack...
As for the locking hood latch - the pull handle is pretty much resting up against the firewall at the moment due to the short cable but it works and will keep people from just walking up and popping the hood open (I'll re-cable it at some point) - it just bugs me that I can't get the hood lined up right on all sides...
Old Aug 14, 2009 | 10:11 AM
Jermafenser's Avatar
Jermafenser
It's hard to find a good set. They had a design flaw to begin with. They stretch and buckle over time.
People slamming it down to close from a foot didn't help any, either!
Jermafenser
Old Aug 14, 2009 | 11:22 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
1973/79 F100/350 & 1978/79 Bronco Hood Hinges
I also have the high hood at the cowl.
You wanna know why?
At some point the hood flew up stretching the hood hinges. This is a VERY common problem with these trucks.
The only fix is to replace the hinges.
For years, people have slammed these heavy hoods down, over time the hood latch's lock support plate bends downwards.
It's EZ to verify this...when the hood is down, stick your fingers under the lip of the hood and lift. If there's an inch or so of play...watch out, because...
Sooner or later, usually sooner...the hood will fly up.
This problem first reared its ugly head in 1967, and was still a problem in 1979.
1973/79: F100/350 & F500/880 // 1978/79 Bronco.
D3TZ16796A .. Right Hood Hinge / Obsolete
GREEN SALES CO. in Cincinnati OH has FOUR = 800-543-4959.
JST AUTOMOTIVE in Lebanon TN has ONE = 615-443-3086.
PARTS INTERNATIONAL in Farmers Branch TX has ONE = 888-727-0418.
KINSEL L/M in Beaumont TX has ONE = 800-816-2894.
KLIMESH MOTOR SALES in Calmar IA has ONE = 563-562-3241.
MORLAN-SHELL FORD in West Plains MO has ONE = 417-256-3195.
PERRY FORD in San Luis Obispo CA has ONE = 805-544-5200.
FITZPATRICK & LAMBERT Ford in Dushore PA has ONE = 570-928-8184.
D3TZ16797A .. Left Hood Hinge / Obsolete
DON SANDERSON FORD in Glendale AZ has 17 = 623-842-8762.
MILLER OBSOLETE PARTS in Binghamton NY has FOUR = 800-546-7278.
GREEN SALES CO. has THREE.
JST AUTOMOTIVE has TWO.
Diesel_Brad
Aug 22, 2015 07:22 PM
topscrt
37
May 12, 2013 12:08 AM
Diesel_Brad
Jun 12, 2012 12:55 AM
Diesel_Brad
220
Jun 6, 2011 04:12 AM
rotun
May 7, 2010 09:31 AM
