Sponsored by: Real Truck
Post your air compressor install pics
Old Apr 29, 2010 | 11:55 AM
rotun's Avatar
rotun
Reads ***** rules!
Alright everybody, thought it would be nice to have a compilation of installs on SUPER DUTY's ONLY!
Post your make/ model compressor and tank size.
Here's mine........
Oasis XD4000
5 gal. tank.
<a href="http://s491.photobucket.com/albums/rr272/RotunTuna/?action=view&current=XD4000-2.jpg" target="_blank"><img src="http://i491.photobucket.com/albums/rr272/RotunTuna/XD4000-2.jpg" border="0" alt="Photobucket"></a>
<a href="http://s491.photobucket.com/albums/rr272/RotunTuna/?action=view&current=ofc09025.jpg" target="_blank"><img src="http://i491.photobucket.com/albums/rr272/RotunTuna/ofc09025.jpg" border="0" alt="Photobucket"></a>
<a href="http://s491.photobucket.com/albums/rr272/RotunTuna/?action=view&current=ofc09026.jpg" target="_blank"><img src="http://i491.photobucket.com/albums/rr272/RotunTuna/ofc09026.jpg" border="0" alt="Photobucket"></a>
<a href="http://s491.photobucket.com/albums/rr272/RotunTuna/?action=view&current=ofc09029.jpg" target="_blank"><img src="http://i491.photobucket.com/albums/rr272/RotunTuna/ofc09029.jpg" border="0" alt="Photobucket"></a>
<a href="http://s491.photobucket.com/albums/rr272/RotunTuna/?action=view&current=ofc09030.jpg" target="_blank"><img src="http://i491.photobucket.com/albums/rr272/RotunTuna/ofc09030.jpg" border="0" alt="Photobucket"></a>
<a href="http://s491.photobucket.com/albums/rr272/RotunTuna/?action=view&current=ofc09028.jpg" target="_blank"><img src="http://i491.photobucket.com/albums/rr272/RotunTuna/ofc09028.jpg" border="0" alt="Photobucket"></a>
<a href="http://s491.photobucket.com/albums/rr272/RotunTuna/?action=view&current=800069.jpg" target="_blank"><img src="http://i491.photobucket.com/albums/rr272/RotunTuna/800069.jpg" border="0" alt="Photobucket"></a>
<a href="http://s491.photobucket.com/albums/rr272/RotunTuna/?action=view&current=800067E.jpg" target="_blank"><img src="http://i491.photobucket.com/albums/rr272/RotunTuna/800067E.jpg" border="0" alt="Photobucket"></a>
<a href="http://s491.photobucket.com/albums/rr272/RotunTuna/?action=view&current=800066.jpg" target="_blank"><img src="http://i491.photobucket.com/albums/rr272/RotunTuna/800066.jpg" border="0" alt="Photobucket"></a>
<a href="http://s491.photobucket.com/albums/rr272/RotunTuna/?action=view&current=800062E.jpg" target="_blank"><img src="http://i491.photobucket.com/albums/rr272/RotunTuna/800062E.jpg" border="0" alt="Photobucket"></a>
<a href="http://s491.photobucket.com/albums/rr272/RotunTuna/?action=view&current=800063E.jpg" target="_blank"><img src="http://i491.photobucket.com/albums/rr272/RotunTuna/800063E.jpg" border="0" alt="Photobucket"></a>
Old Apr 29, 2010 | 12:20 PM
Buckholz's Avatar
Buckholz
Dang, I love it. Could you install a nitrogen generator too, so your tires wouldn't blow up with that air you are compressing? ;o)
Old Apr 29, 2010 | 01:39 PM
SteveBricks's Avatar
SteveBricks
FTE Leadership Emeritus
FTE Emeritus
Looks great Derek.
Where did you pick up power for the compressor? Are you switching it from one of your upfitters?
Old Apr 29, 2010 | 01:55 PM
grec-o-face's Avatar
grec-o-face
I'm looking to do an on-board air set up myself. I'm hoping to just piece something together (hopefully keeping the cost LOOOWWW).
Any ideas?
Anything I should consider a 'must have' or a 'must not have'?
Old Apr 29, 2010 | 02:27 PM
senix's Avatar
senix
Not that high tech but here is mine:
Attached to the tank braket.
Feeds the air tanks under drivers door:
Outside air
Old Apr 29, 2010 | 06:39 PM
rotun's Avatar
rotun
Reads ***** rules!
Steve, I wired in a self switching battery isolator and added a third battery real close to the compressor. I wired a separate switch to the inside of the cubby box (next to the right knee on the dash, below and right of the up-fitters) didn't want to have the key on for the compressor to run. I also pull power from a junction close to the 3rd battery for the stereo amps.
The isolator only supplies power to the 3rd battery (from the oem batteries) when there is more then 13v (when charging), this way the draw on the 3rd cannot kill the oem batteries for starting.
I'll post more pics when I get home....don't have the cord to my camera here.
Old Apr 29, 2010 | 06:46 PM
rotun's Avatar
rotun
Reads ***** rules!
Any ideas?
If going with a small compressor, try to get as much tank as you can. Try to use d.o.t. tubing as well...it is rated for really cold temps and used in air brake applications. You'll also want to plumb the intake to the inside of the cab so you're not pulling dirt into the compressor. Viair makes good 12v compressors, in the interest of saving $...my suggestion is to just buy the system piece by piece and don't settle for the cheap stuff, otherwise you'll end up spending more down the road to replace it.
Old Apr 29, 2010 | 07:42 PM
fordsd350's Avatar
fordsd350
So here's my 10" X 31", refurbished semi air tank (~ 11 gallons) installed on the inside of the driver's side frame rail.
I welded up some brackets that bolt to the frame rail and re-used the original hangers (threaded round stock) to hang the tank. The tank hangs down about 2-3" below the frame rail.
I'm using dual 400c compressors mounted in my tool box to fill the tank.
I'm using two muffin fans to draw air through the box to help cool the compressors. The compressors and fans are controlled by the pressure switch via three relays.
I have a 1/2" line and solenoid valve supplying air to my everyday horn (single bell Buell).
Below the solenoid valve is another 1/2" ball valve that isolates the external air fitting.
The air fitting is located in a factory hole just below the front of the rear passenger's door (on driver's side).
Old Apr 29, 2010 | 08:08 PM
rotun's Avatar
rotun
Reads ***** rules!
That's a nice setup. I'll eventually add a tank like that too. Right now I'm working on finding a place for the K5LA train horns.
Steve, here's the pics.
3rd battery (gel cell, deep cycle)
<a href="http://s491.photobucket.com/albums/rr272/RotunTuna/?action=view&current=trk002.jpg" target="_blank"><img src="http://i491.photobucket.com/albums/rr272/RotunTuna/trk002.jpg" border="0" alt="Photobucket"></a>
Junction blocks
<a href="http://s491.photobucket.com/albums/rr272/RotunTuna/?action=view&current=trk004.jpg" target="_blank"><img src="http://i491.photobucket.com/albums/rr272/RotunTuna/trk004.jpg" border="0" alt="Photobucket"></a>
Isolator
<a href="http://s491.photobucket.com/albums/rr272/RotunTuna/?action=view&current=trk005.jpg" target="_blank"><img src="http://i491.photobucket.com/albums/rr272/RotunTuna/trk005.jpg" border="0" alt="Photobucket"></a>
<a href="http://s491.photobucket.com/albums/rr272/RotunTuna/?action=view&current=trk006.jpg" target="_blank"><img src="http://i491.photobucket.com/albums/rr272/RotunTuna/trk006.jpg" border="0" alt="Photobucket"></a>
hidden switch
<a href="http://s491.photobucket.com/albums/rr272/RotunTuna/?action=view&current=trk007.jpg" target="_blank"><img src="http://i491.photobucket.com/albums/rr272/RotunTuna/trk007.jpg" border="0" alt="Photobucket"></a>
tank, again
<a href="http://s491.photobucket.com/albums/rr272/RotunTuna/?action=view&current=trk009.jpg" target="_blank"><img src="http://i491.photobucket.com/albums/rr272/RotunTuna/trk009.jpg" border="0" alt="Photobucket"></a>
plumbing to cab for inlet, amp feeds
<a href="http://s491.photobucket.com/albums/rr272/RotunTuna/?action=view&current=trk008.jpg" target="_blank"><img src="http://i491.photobucket.com/albums/rr272/RotunTuna/trk008.jpg" border="0" alt="Photobucket"></a>
inlet air filter (behind rear center console)
<a href="http://s491.photobucket.com/albums/rr272/RotunTuna/?action=view&current=trk010.jpg" target="_blank"><img src="http://i491.photobucket.com/albums/rr272/RotunTuna/trk010.jpg" border="0" alt="Photobucket"></a>
Old Apr 29, 2010 | 08:16 PM
Rugby3's Avatar
Rugby3
Those are some nice set ups!
Old Apr 29, 2010 | 09:48 PM
1975StroppeBaja's Avatar
1975StroppeBaja
Nice air compressor setups.
Reps to all who have posted up pics. Well, except for Senix, gotta spread it around more first. Can somebody rep Senix for me?
This is something that would be awesome to install and setup but I don't have an immediate use for it. Its pretty low on my to-do list. Maybe someday I'll install some bags on the back and do it.
Old Apr 30, 2010 | 07:19 AM
grec-o-face
Rotun, You don't have any spare Nathans for sale, do you? A friend is in the market for a set-up.
Thanks for the good ideas.
Old Apr 30, 2010 | 09:58 AM
BigPigDaddy's Avatar
BigPigDaddy
Could you guys give is a heads up as to where you got your components?
Thanks!
Old Apr 30, 2010 | 10:29 AM
rotun's Avatar
rotun
Reads ***** rules!
Sorry, bought mine on ebay for $630 from taakersc (Ted Akers).
http://cgi.ebay.com/ws/eBayISAPI.dll...m=200442340817
Did alot of searching and $aving and found a few but were not rebuilt so I went ahead and bought from Akers. Depending on how long he can wait, just keep checking Craigslist, ebay.
Old Apr 30, 2010 | 10:34 AM
rotun's Avatar
rotun
Reads ***** rules!
Thanks!
I bought the Oasis online from the cheapest dealer I could find, was still $spendy though. As for the d.o.t. lines we have a place called "Hose Man" here that makes, stocks every kind of hose/ fittings anyone could ever need. Some of the components I purchased here. Train Horn Kits & Air Suspension By HornBlasters, The Name In Locomotive Air Horns!
