6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
Edge insight
Old Jul 19, 2009 | 09:55 PM
Softballdad's Avatar
Softballdad
Edge insight
Just wondering what are the most important temperatures you don't want to exceed, and should be monitored when towing. If the max temperature is reached do you back out of the throttle or what?
Old Jul 20, 2009 | 01:03 AM
trfdfirefighter's Avatar
trfdfirefighter
i have the edge dpf delete tuner, with cat and dpf gone, mine alarms at like 1300 degrees but when i really stand on it or run it hard i've seen temps just up to like 1800 on the egts. what i watch close is engine oil temp and ect which alarm at 230 degrees and if your towing watch the trans temp. while towing the egts normally run about 1000 to 1200 i've seen normal temps. being as you titled the post edge insight i'm assuming that you have an edge insight which you should be able to set temp alarm points to alert you if they are reached and if they do def back out of the throttle.
Old Jul 20, 2009 | 06:34 AM
Softballdad
I did get the insight so I could monitor the engine functions, but I haven't run across anything that says what parameters to set. I hope to hear more on what trans temps to keep an eye on.
Old Jul 20, 2009 | 06:43 AM
trfdfirefighter
trans temps above 230 i think is where that alarm should be set and egt's above 1300
Old Jul 20, 2009 | 07:23 AM
ruschejj's Avatar
ruschejj
My insight will not give me the trans temp. I called the edge people and for some reason they can't get it. If you have it on your insight I'm jealous and confused.
Old Jul 20, 2009 | 08:49 AM
Leonandlisa's Avatar
Leonandlisa
I also cant get the trans temp on my edge insight, I haven't called about it but if someone hears back on how to get it that would be helpful. On the EGT which sensor are you watching?
Leon
Old Jul 20, 2009 | 09:28 AM
Softballdad
I believe under Ford specific is where you will find the trans settings.
Old Jul 21, 2009 | 12:43 AM
trfdfirefighter
i watch the egt closer to the engine. mine tuner is only like 6 weeks old according to manufacturers date. they should be internet updateable maybe edge can do something for you if you contact them?
Old Jul 25, 2009 | 09:44 AM
mlbmd's Avatar
mlbmd
Trans temps were lost with one of the program updates. Edge reprogrammed the "update" back to an earlier version and I was able to get trans temps back again.
Grinder Man
Oct 10, 2014 09:35 AM
ten.mile
Dec 11, 2012 05:56 PM
Aune163rd
Modular V10 (6.8l)
Jun 2, 2012 03:28 AM
glsurratt
6.7L Power Stroke Diesel
Dec 1, 2010 07:39 PM
EBExpedition
Dec 15, 2007 10:33 PM
