no cool/ cold air
Old Nov 22, 2007 | 09:59 PM
EBExpedition's Avatar
EBExpedition
no cool/ cold air
Hello everyone,
I have a 99 Eddie Bauer Expedition with 87k on it. I have the automatic climate control and I don't get any cool or cold air when I turn the temp down it blows warm/hot all the time. Any ideas what this could be? A temperature sensor of some sort? The engine temp is in the normal range. Do you think it could be anything other than a blend door?
Thanks,
Steve
Old Nov 25, 2007 | 08:26 AM
EBExpedition
no one knows?
Old Nov 25, 2007 | 09:28 AM
cmachk's Avatar
cmachk
My AC compressor went out in my 98, only blew hot air. I took it to a friend who kept refilling the ac until I found the money to replace the compressor. After that, blew cold as ice and still does, that was 6 years ago!
Old Nov 25, 2007 | 05:48 PM
heymrdj's Avatar
heymrdj
Yeah definitely sounds like your compressor is dead. Auto A/C repair center should be able to do it easy enough, if not still take a chunk of $$$. Good luck.
Old Nov 25, 2007 | 06:25 PM
FTE Herman's Avatar
FTE Herman
Could be a compressor, could be a blend dorr, could be something else. I'd first check and see if the compressor is turning and if the low side (return) line is cold. If this is the case, I'd say the compressor is fine.
Old Nov 26, 2007 | 03:27 PM
EBExpedition
Yeah, I'm pretty mechanically inclined Iwent to college for automotive so if it was the compressor i would do it myself. But I dont think it is the compressor,when I turn it to "vent" (which the air compressor is not used in this mode) it still blows hot. So I am thinking it is a blend door. I haven't had a chance to check to see how and if the compressor clutch is cycling but I will first chance I get. Its raining right now though.
Old Nov 28, 2007 | 11:22 PM
smahon's Avatar
smahon
Do you have cold air in the rear?
Old Nov 28, 2007 | 11:23 PM
EBExpedition
yes. Thats another reason it is not the compressor. I forgot to add that.
Old Nov 28, 2007 | 11:32 PM
smahon's Avatar
smahon
I feel your pain! Really. I'm goin' in for the blend door this weekend myself (if I can get the parts in time).
Old Nov 28, 2007 | 11:34 PM
EBExpedition
Really? Please let me know how it goes, and if you run into anything along the way.
Old Dec 15, 2007 | 10:33 PM
smahon's Avatar
smahon
Yes! I have heat!!!! The procedure went fine, 10 hours by myself. I used the "saws-all" method of removing the heater core by cutting the pipes from the inside and pulling out the hoses from the engine compartment. If I had not already known to look for a damaged blend door, I never would have seen it. In fact, the only way to see the damage on mine was to spread the flange apart with a screw driver to see it was cracked. I skipped all the optional steps and still had enough room to work with the dash just pulled out on an angle. If you have to remove the center console (I did) and you have electric seats, make sure you do this before you disconnect the battery. The seats have to move forward to get to the 2 screws in the back, but you'll want to move them back to give you room to work after the console is out. Good luck, stay patient.
Skypilot1957
27
Jan 19, 2010 01:36 PM
SG1NUT
Mar 20, 2008 08:50 PM
WhoKnows
16
Feb 21, 2008 09:31 PM
WhoKnows
Feb 16, 2008 12:10 AM
pgonza2723
Dec 17, 2007 01:59 PM
