Sponsored by: Auxito
1999 brakes
Old Jul 18, 2009 | 10:59 PM
golddirt's Avatar
golddirt
1999 brakes
I have a 99 cab and a half short bed 5.4 front disc and rear drum brakes. I never had this issue before so looking for some that have. when i hit the brakes you can hear the abs working, but no reason for it to. brake ped is hard and on very top and basically will not let me stop. where do i start. thanks
Old Jul 18, 2009 | 11:35 PM
Tex1986's Avatar
Tex1986
First off, do you have 4 wheel abs? If not, then it's because your back shoes are set too tight and that's where the abs kicks in for only the rear brakes. That's what I've seen with my truck but the techs here more than likely have a more technical answer for you
Old Jul 19, 2009 | 06:53 AM
torkum's Avatar
torkum
A hard brake pedal would indicate a bad brake booster.
Old Jul 19, 2009 | 07:46 AM
golddirt's Avatar
golddirt
it dont do it all the time, yet .
Old Jul 19, 2009 | 08:05 AM
golddirt's Avatar
golddirt
I forgot to mention that the abs light comes on but will go off after a few restarts. 4 lines coming out of abs unit so i guess that means 4 wheel abs
Old Jul 19, 2009 | 06:51 PM
golddirt's Avatar
golddirt
peddle is not hard all times, also when stopping, is fine at times untill almost stopped then abs again. weird
Old Jul 20, 2009 | 03:44 AM
golddirt's Avatar
golddirt
anything? am i the only one
Old Jul 20, 2009 | 10:04 PM
golddirt's Avatar
golddirt
never mind traded for an 07 4x4 now up to the next forum
Old Aug 11, 2009 | 01:07 PM
Buck200x's Avatar
Buck200x
I have the same problem but mine is 4wheel disc. Did you find an answer before you traded it? If I go over a bump, the next time I hit the brakes it feels like the abs kicks in. It doesnt matter if I hit the brakes a few minutes after going through the bumps. The peddle will go soft like it does in abs mode and I can feel it pulsate. It will some times do it after traveling for 10 or more miles down a highway. The bad thing is that it doesnt do it all the time.
Old Aug 11, 2009 | 09:30 PM
golddirt's Avatar
golddirt
no i didnt, i figured new calipers, rotors and everything else was more than it was worth and 10-4 on the abs always seemed to be engaged. i sure am glad i got the 07, should have traded a year ago as the value really dropped the last year. now i can't wait for snow as this is the 1st 4x4 i have ever owned. if you find out let me know what the main culprit was please.
Larzon
Nov 18, 2012 06:56 PM
ironelk1016
Aug 27, 2010 06:48 PM
afonda
Dec 26, 2008 01:56 AM
rocky39742
20
Sep 11, 2007 05:03 PM
nikwave
Feb 27, 2004 05:32 PM
