Paint Codes
Old Jul 18, 2009 | 12:04 PM
SouthernBlues's Avatar
SouthernBlues
Paint Codes
How do I find the paint code on my truck. The paint on my roof and hood are faded and was thinking of repainting them.
Old Jul 18, 2009 | 02:22 PM
phoneman91's Avatar
phoneman91
Look at the VIN( officially called: SAFETY COMPLIANCE CERTIFICATION LABEL) sticker on the driver's door jam-near the strike plate for the door latch. There is several categories listed on this VIN sticker. Look for EXTERIOR PAINT COLORS category. Should be near the lower left corner of this VIN sticker. The paint code will have two characters-alpha and numeric or just alpha. If there are two sets of two character codes-each code will represent a paint color-and the truck is/was a factory two tone.
Take a look and give us the codes and we can tell you what color of paint you have-what the marketing name is .
This VIN sticker will also tell you what axle ratio the truck was equipped with at the factory,color and type of interior,limited slip or open differentials, pin/tape stripes,GVWR, rim size,spring code,GAWR,transmission and DSO/ district office/domestic special order codes.
Old Jul 18, 2009 | 02:39 PM
SouthernBlues
This VIN sticker will also tell you what axle ratio the truck was equipped with at the factory,color and type of interior,limited slip or open differentials, pin/tape stripes,GVWR, rim size,spring size,GAWR,transmission and DSO/ district office/domestic special order codes.
It has LA 24
Old Jul 18, 2009 | 03:01 PM
phoneman91's Avatar
phoneman91
The "LA" is "Medium Royal Blue Poly" Clearcoat. LA/M6504A.
Take a look at this website:
http://www.tcpglobal.com/aclchip.asp...truck-pg03.jpg
I don't see a "24" code for a 95 F series.
Old Jul 18, 2009 | 04:51 PM
SouthernBlues
Thanks for the info, the Med Royal Blue is my color
Old Aug 16, 2010 | 08:26 AM
presidentsdad's Avatar
presidentsdad
Hey..I have UA and FN for my paint codes...what would those be?
Old Aug 16, 2010 | 02:15 PM
phoneman91's Avatar
phoneman91
For your 1996 F250:
See:
http://www.paintscratch.com/
They say that the "UA" is Black Ebony Clearcoat UA/M6373 and that the "FN" is FN/M6800 Toreador Red Pri Metallic Clearcoat.
Old Aug 20, 2012 | 06:31 AM
92fleetside's Avatar
92fleetside
I have the same problem i thought that my paint code was dj3 but that might be the lower body trim color.
Old Aug 17, 2015 | 09:01 PM
RenoDan's Avatar
RenoDan
What color is my truck? here's a picture of the sticker in the door jamb I can't figure out which numbers or letters are the paint code and I want to buy some touch up paint thank you
Old Aug 18, 2015 | 05:08 PM
Diesel_Brad's Avatar
Diesel_Brad
You have an 0353. What ever that is. It doesnt come up in any color chart I have
sccamper
Mar 13, 2016 08:37 AM
Richard2212
Paint & Bodywork
Mar 12, 2016 09:03 PM
weeeves
Feb 4, 2016 02:22 PM
wanta65
Nov 22, 2015 04:02 PM
bykpainter
Oct 28, 2015 10:30 PM
