Brake Pressure Switch
Old Jul 17, 2009 | 12:27 AM
edsf100's Avatar
edsf100
Out of the blue my fuse blew for the brake lights. Traced it to the pressure switch. one of the leads on the switch ohms to ground. Need to get one. anyone have this problem???
Old Jul 17, 2009 | 12:42 AM
Julies Cool F1's Avatar
Julies Cool F1
It's probably starting to rust out inside and is shorting. Your problem is not that uncommon. You can get them any where - all the "resto parts palces" carry them.
Old Jul 17, 2009 | 08:08 AM
BlueOvalRage's Avatar
BlueOvalRage
Do a search for "Ford truck fires" and you'll find some scary stuff. Ford used this same type of switch in their trucks from '92 into the beginning of this decade as a means of disengaging the cruise control when the driver stepped on the brakes. The switch was powered all the time and had a tendency to short out, overheat, and set the truck on fire - usually when it had been parked for hours. They work and they're OK as long as they're fused, but I personally replace them with a mechanical switch when I can. Corrosive brake fluid just doesn't really mix well with electrical parts. Just something to think about!
Old Jul 17, 2009 | 10:31 AM
edsf100's Avatar
edsf100
Excellent advice. Thank you.
Old Jul 18, 2009 | 12:23 AM
edsf100's Avatar
edsf100
Use a 55 chevy switch. Mounted on the fire wall the the arm goes under the brake pedel. Works great. Also changed the rear lights complete sets. Just need to take out the pressure switch and plug. Thanks!!
Truckee Bones
Jun 12, 2014 05:48 PM
dieselbronc
Large Truck
Sep 3, 2010 09:31 PM
lurch460
May 18, 2009 12:40 PM
jpdover
Jun 10, 2006 05:54 PM
Frank Scarabino
Sep 9, 2003 12:49 PM
