1976 F600 brake pressure proportioning valve
You need a factory manual that covers the functions of the valve. They have a switch that monitors the position of an internal plunger. The plunger moves to one side if a brake line ruptures sealing that side off. There may also be a pressure compensation valve inside.
Check with the online store here to see if the Factory service manuals they have on CD cover the HD trucks. My paper manuals cover the heavy trucks but I don't have your year.
I have never seen any F Series Ford Truck with tilt Cab. Are you sure you have an F600?
Also what you seem to be talking about is Air Brakes not Vacuum over Hydraulic, or Hydra Vac Assist.
Air brakes have a B1 splitter valve facilitatating different ways to charge system with air @PSI to activate the air brakes. . . . .
FWIW, foot valve, trolley valve & Park Valve all operate the brake system, but do it through one set of lines to chambers, not 3sets.
I am totally confused
Diesel_Brad
Other; Brakes, Electrical, Hitches, Weight Distribution & CDL Discussion
25
09-27-2015 06:33 AM
flipklos
03-30-2010 08:13 PM
tonpartain
04-12-2006 09:58 AM
