Can I remove the electronics as in the intake system and put a carb, intake and set it up??
I am trying to reduce the sea of sensors and hoses on this beast.
Any suggestions would be apppreciated. Thanks.
J
wow...I can't believe no ones answered yet.... Being i'm going through the EXACT same thing right now with an 86' f150 and 89' 5.0 hyd. roller engine.......Answer is yes, and here is how you need to do it.....get ahold of a good carburetor, intake manifold of your choice.....Here is where its gets complicated: If you have an AOD trans you WILL HAVE TO BUY a throttle valve cable to carburetor conversion one from Lokar works great. If you have a standard no problem. Next up, ignition system. If you have fuel injection, your distributor WILL NOT WORK for a carb engine. Convert to an earlier Ford Dura spark ignition box and distributor.....or like myself go all aftermarket with MSD ignition......Trouble I'm having is where to wire the msd box in at!!......thats about all I can think of......the ignition and if its an aod you have to have a conversion kit for the Throtle valve linkage to work right. Hope this helps......oh yea one more thing....If you have a roller block like mine with roller cam your distributor must have the right gear on it......standard flat tappet 302 is all good...just a replacement distributor is all you need for a carbureted 302. I recommend the duraspark stuff or something with a magnetic pickup (distributor)
Reason: Removed Link to his site
J
You will need a distributor with weights, springs, and a vacuum advance to control your timing.
If you decide to get a new distributor, consider our custom curved Duraspark Distributor built with our new Full Length Oil Impregnated Bronze Bushing. The full length bushing improves timing stability and spark scatter. If stock appearance is not an issue, take a look at our one piece D.U.I. Distributor. Whether you choose the Duraspark or the D.U.I., we curve each on a distributor machine based on your engine combination. Please see them at:
Ignition Lesson of the Month: Hystereses, the difference between the timing as the rpm and vacuum increases to the timing as rpm and vacuum decrease, needs to be kept to a minimum. A precise advance curve accomplishes this.
hey
i also want to ditch the efi on my 85 f150
what about wiring set up? can i use a stock carb wiring harness?
what about throttle cable?
carb size / cfm?
a good stock manifold w/o crap on it?
i have a t19 man trans
i have to keep my smog pump for insp (pa)
TY
RR63
