Intake manifold ?'s
Old Feb 13, 2017 | 10:19 PM
56f1000's Avatar
56f1000
Intake manifold ?'s
I have an 89 fuel injected 5.0 302. If I were to switch it to a carbureted intake manifold. Anyone know what years would fit??
Old Feb 14, 2017 | 08:11 PM
TireDood's Avatar
TireDood
any carburetor intake should work. I have 2 of the later model 302's, one with an Edelbrock Performer intake, and the other has a stock 4 bbl intake from an '83 Mustang. Once you remove all the fuel injection stuff (intake, fuel rails, etc.) it's just a normal old 302.
Old Feb 14, 2017 | 08:34 PM
Scotty's 52 F3's Avatar
Scotty's 52 F3
TireDood is correct. I have 289 and 302 manifolds on 5.0's no problem.
Old Feb 15, 2017 | 01:09 PM
petemcl's Avatar
petemcl
Edelbrock or Offy should work. Available from several sources: Amazon, Jegs, Summit Racing, etc. Just don't choose the high performance models unless your engine is set up with higher compression, hot cam, higher rev, etc. Otherwise you will be disappointed. Your engine needs to have the right balance.
dstraw
Jul 1, 2019 09:52 PM
moparman19
Sep 7, 2011 09:46 PM
TheTowingCowboy
19
Oct 23, 2007 08:29 PM
rellikkcaj
Jan 19, 2007 12:58 PM
sierraben
Jan 4, 2005 10:23 PM
