So I've installed new cam bearings in my 360, and darned if I just can't get the cam to fit in nicely. It keeps hanging up on the #2 bearing. I tried straighting the bearing, and carefully reinstalling it - but fitting the cam from the front or the rear - it just won't go
I thought that the bore might be off, but a simpler answer might be I got the wrong bearings, or mixed up their order. Does anyone know the ODs of the cam bearings so I can measure it?
No, I was looking for OD of the bearings. The bearings slip onto the cam nicely when they are outside the block, but once installed, the cam hangs on #2.
Now I suspect that the #2 bore is out of whack because when I place a straight edge through the cam bores, #2 is high on one side, and low on the other. I was told that the bores get smaller from front to back?
I wanted to know the bore diameters make sure I wasn't crushing the wrong bearing in there.
Cam Bearing are larger Id from the front of the block to the back... If they were larger in the back the cam couldnt get passed the first bearing..
I hope you installed them with a cam install tool ? and god please dont nick a bearing..you'll never get the cam journal past that spot...alway use a come installation tool unless your real good with useing long bolts at the front of the cam...
You maybe out and buying a new set of bearings.. If you havent ever installed a cam before..Take it to the shop and have it done...Or if you have a buddy that has the toold to do it right go that way.. a Bad cam install will wreck your whole project ! JMO..And good luck..
I'm pretty sure that I didn't have bearing #1 cocked, but I am at the point where I will probably take it to the shop. We used a homemade cam installation tool made with threaded rod and some collets that fit o.k. Still had to occasionally tap it straight while pulling. Took our time doing it too. Also, redid the #2 once just to make sure.
Now, I *think* that the ID of all the bearings are the same - at least we were able to get the cam in through the back... just up to the #2 - which makes me think that that bore just isn't right.
Well I have seen to many can tunnel's distort or go out of round unless it spun a cam bearing...and if one cam came out another of the same should go back in..But nicking a cam bearing is very easy to do if you have never installed on before with new bearings..
But only making it up too the second cam journal, Obvisouly aint right.. Is it a new cam ? Did you mic the cam journals on the cam ?
Thanks guys. With my harbor freight calipers my bearing i/ds were 2.127 - 2.129 - the #1, however was a little tight 2.123...it felt tight on my old cam too.
so I'm ordering a cheapo set of bearings, and gonna try replacing the #1, and see if that gives the whole thing enough clearance to slide in. Like I said before, I still think the #2 bore is a little off, so hopefully that bit of clearance will loosen everything up - if not I plan to cut some grooves in the old cam and try out a homemade reamer! (also why I orderd some more bearings
I did find some more information online about the OD of the cam bearings. On a 460 build...
Well I hope it all works out for you.... I'am not a firm believer in cheapo bearing tho.. Bearings and the oil pump are the only protection you have in the motor... For Street motors and street / Strip motors I like the Dura Bond Cam bearings..and there not all that much money.. BTW its hard to get a good reading with a set of calipers....A dail bore gage is really the way to go !
I'm posting this because I saw a new post on having troubles fitting the cam into a rebuild. I wanted to follow up on my adventures with this.
I went ahead and made a reamer out of my old cam by cutting slits in it as described by the article I mentioned. I just used an angle grinder. FYI, make them at an angle, not straight across, or the chips will jam up your reamer. Just work really slowly, and I kept WD40 on it. You might have to back it out to clean up chips part way through the process. This is important, because the reamer will jam, and scratch up the bearings. The new cam fit perfectly after this.
I was waiting 'till I had some miles on my engine to say how it went. I now have 1400 miles on my rebuild, and checked the oil at 100/1000 miles for chips - and all seems good!
Keep in mind, this was my first rebuild and I'm an amateur at engine rebuilding, but this seems to have worked.
The problem for me was that the cam bores were not lined up in a straight line in my block. Whether it was warping or a factory defect - I don't know
