Rebuilding a 460. Engines been bored 20 over, new pistons etc. etc..... installed the cam bearings and went to install cam and it wouldn't fit.
Tried to chamfer the edges of the bearings and still no fit. Popped the bearings out and tried them over the cam journals, fit OK. Not as good as I'd like, but they slid over the journal. Popped them back into the block and cam wouldn't fit.
Mic'ed the cam journal at 2.124" which is spec in the book so the cam is OK, but when I mic'ed the ID of the installed bearings they were at 2.122 to 2.124-5. These are brand name bearings.
Anybody ever have this problem? Anybody know what the ID should be for uninstalled cam bearings?
I believe that crush is .001" per inch of diameter for a pressed fit. So I'm thinking that at 2.1", crush would be about .002", so the uninstalled ID should be 2.126-7.
Any ideas. I'm going to order another set and try it again.
Mike the cam bore before putting the bearings in I have seen those not be right and have seen the factory make up special bearing(s) to fit. Though they where usually to big not to small.
ive never seen them not fit before i know they are tight but not that tight i would maybe got get some new bearings and mic them to see what they are too. try a diff brand than what you have first.
The 460 cam bearings are the same size from one end to the other I have seen them put in cocked and that makes them real tight. Drive those out get a new set and mic everything then install them with a tool that aligns them up concentric to the cam bore
That was my first thought that they might be cocked. I mic'ed the bearing edge from the face of the cam bore to the edge of the bearing to make sure it was square. It was. I have a K-Line cam installation tool. Should get the new bearings tomorrow by FedEx so I'll try it again. I'll put in a call to DANA Corp and talk with one of their engineers about it if I have the same problem.
Found the problem. The cam bearing closest to the timing chain has two holes, one from the oil filter and one to the cam journal. The area where the oil from the filter comes through the block had a slight bump in it that caused the bearing to distort out of round. Filed out the bump, installed the new bearings and cam goes in without a problem.
