4 speed with a PTO???
Old Nov 26, 2000 | 10:26 PM
Rosati's Avatar
Rosati
I have a 4 speed with a PTO located on the passenger side. The plate on the PTO is missing but the #'s stamped in its place are
E 3
CI-P-223
The tranny #'s on the drivers side are:
T96-1R
W.G. DIV
N-1
The casting code(?) located near this looks like "H12-3"
I have no clue as to the originality of these parts to my '66 F350 but I am looking to figure out what I have.
Krosati
Old Nov 27, 2000 | 10:10 AM
StockMan's Avatar
StockMan
[FONT COLOR="#0000ff" SIZE="3" FACE="Veranda"]
You likely have either a Warner T-18 or the NP-435. Here's a handy ID guide.
[LINK:www.hometown.aol.com/tbeeee/page/4-speed.html|4-spd Manual Tranny I.D.]
[/FONT]
[LINK:www.hometown.aol.com/tbeeee|http://members.aol.com/tbeeee/page/67registry.jpg]
Old Nov 27, 2000 | 07:50 PM
Rosati's Avatar
Rosati
I haven't looked at the tranny much yet but it also has a brake drum/parking prake between the tailshaft and the drive shaft but the linkage is missing. I was hoping to get some information as to what else these gearboxes were in so I can scrounge up the needed parts.
Krosati
Old Nov 28, 2000 | 06:28 AM
DannyP's Avatar
DannyP
It sounds as thought your mystery tranny is from a large truck, as they have the parking brake mounted as you describe.The PTO was probably used to run a hydraulic pump for a dump. Sorry I can't be of any more help than that.
DannyP
89 F-150 4x4 former EFI I-6 now carbed 351W, Edelbrock heads,cam,intake,carb.
MSD 6A, ZF, Sterling 10.25 with 3.55L's.
Old Nov 28, 2000 | 09:49 AM
lee's Avatar
lee
Hi, In my set of 1970 Ford service manuals is a picture of a transmission with the brake set up at the output of the Tx as you discribe. The Tx is a NP 435. I think that this was a common set up for large trucks only as my 1970 F250 has the NP 435 but not this kind of parking brake. As a side note, every M-series large military truck that I have seen also have this kind of parking brake.
Lee
Old Jan 20, 2001 | 10:28 PM
Trail_Rider's Avatar
Trail_Rider
Stockman,
That is very good to know information. Thanks.
Trail Rider
Old Jan 21, 2001 | 01:22 PM
alpo23's Avatar
alpo23
The tranny in question is stock for the '66 F-350. Every F-350 with duel rear wheels I've seen in the junk yards has had a hand E-brake located on the passenger side of the tranny. I'm not 100% cetain that the F-350 with single rear wheels got it too. It seemed to have been a 1-ton and heavier deal. F-250's didn't get the hand brake. I believe you have an origanal tranny, not a swapped unit.
Eric
Proud owner of a '73 F-250 4x4 High Boy, 460 V8, NP435, NP205
And a '68 Bronco 289 v8 , NP435 , Dana 20
Old Jan 21, 2001 | 01:33 PM
Rosati's Avatar
Rosati
>side of the tranny.......
>Eric
Thanks Eric for the information. Since you have seen these in the salvage yards, what would it take for me to get you to send me the linkage from one of these trucks? I really could use several other parts if you are will to do some scouting for me.
I live in Texas and all I can find are the 1/2 ton trucks that have been scavenged to the frame.
Krosati
Old Jan 21, 2001 | 08:17 PM
alpo23's Avatar
alpo23
I'm sorry to say but my info comes from spending 15 years going to the self serve yards and it has been quite a long time since I've seen one. I've got no guarentee that I could find one faster than you. Over the years they seem to get scarcer and scarcer. I may go to the yards in the next couple of weeks but no promises. Sorry and good luck.
Eric
Old Jan 22, 2001 | 03:42 PM
Rosati's Avatar
Rosati
No need to apologize, I'll take any and all help that I can get!!
Krosati
Old Jan 24, 2001 | 06:46 PM
Eddie's Avatar
Eddie
Does that 4-spd. have a 1-1/16 O.D. 10-spline input shaft?
If so, it is a (don't get mad at me) "light duty" version of a medium duty tranny. The mediums had a 1-3/8" O.D. input shaft.
If it has the PTO on the driver's side, it is a Warner Gear T-18 or T-19 (the 19 is better--syncro low).
If it has the PTO on the driver's side and a tall aluminum top cover, then it is a New Process Gear model NP435 (probably).
For parts like trannies, transfer cases, axles, etc., watch the "classifieds" at this site...I've gotten screamin' deals on all the above items, here.
Eddie
Old Jan 24, 2001 | 08:25 PM
Rosati's Avatar
Rosati
[font size="1" color="#FF0000"]LAST EDITED ON 24-Jan-01 AT 09:42 PM (EST)[/font][p]I took this picture out of the 66 shop manual. It very closly resembles my gearbox but the manual is very vague when it comes to identifying the light, medium, or heavy duty items.
I listed the info cast on the case in my first post. If there are any other markings I should look for, let me know.
If anyone has or has access to the linkage show attached to the parkingbrake and drum, please let me know.
Krosati
http://albums.photopoint.com/j/View?u=327889&a=10579111&p=36007522&Sequence=5&res =high
Old Jan 25, 2001 | 10:49 PM
Rosati's Avatar
Rosati
Here's the picture.
Krosati
https://www.ford-trucks.com/dcforum/User_files/3a710d8356eb02eb.jpg
Old Jan 26, 2001 | 04:28 PM
Eddie's Avatar
Eddie
That's an NP435; see the tall aluminum top cover and PTO cover on the passenger side (sorry about my earlier post saying the pto cover was on the driver's side)?
Also, watch those Ford manuals pretty closely; Ford used the NP435 and Warner T-18 pretty much interchangeably for a long time, and also freely show pictures of the 435 on T-18 rebuild chapters and vice-versa.
I just got done overhauling a '78 NP435 (negligible changes from your '66), and I'm here to tell you it was dead easy! Overhaul kits were cheap too, from Standardtransmission.com
Eddie
Old Jan 28, 2001 | 01:27 AM
fordextreme's Avatar
fordextreme
6.0 and 7.3 United
Mar 18, 2017 11:32 AM
L6powerrunner
Dec 6, 2016 09:17 PM
iggybob44
Jul 11, 2013 01:32 AM
scottf250us
17
Jul 15, 2009 08:02 PM
