PTO for T18
Old Dec 5, 2016 | 11:59 PM
L6powerrunner's Avatar
L6powerrunner
Talking PTO for T18
So I have a 1986 f250 dually 2wd with a t18 four speed and I am looking for a pto for it and any part number for any brand would be helpful because if you got one chances are you can find the equivalent.
Old Dec 6, 2016 | 09:17 PM
Pkupman82's Avatar
Pkupman82
If it's a diesel, chances are it's a T19 4 speed. As far as PTOs go, I am going to assume you want a cable actuated type. The most common brands are Chelsea and Muncie, you will need one with correct input drive gear so it will be compatible with your transmission. Also what type of equipment will you be running with the PTO? Is there a certain shaft speed needed for the equipment? There are many different ratios available to taylor it to your needs. In order to install the PTO, you will need a shim kit as well.
rebel2112
May 4, 2016 04:20 AM
Jacob84Ford
15
Jan 16, 2015 07:52 PM
hooson
WTB - Parts & other
Oct 18, 2014 06:21 PM
kenwoodul
Feb 10, 2014 05:35 AM
slik
Oct 12, 2000 07:50 AM
