2003 Explorer Issues
Old Jul 14, 2009 | 09:50 AM
mkarafelis's Avatar
mkarafelis
I am having trouble with my 2003 Ford Explorer XLT Sport. It idles very rough, at times upon starting it will almost stall, then catch. There are no codes, no check engines, no service engine, NOTHING. There are times it will run rough and other times when it purrs like a kitten. When I put the AC on, it runs even worse. Can someone help me, please.
Old Jul 14, 2009 | 12:30 PM
shorod's Avatar
shorod
Sounds like you have an issue with the Idle Air Control (IAC) servo or a vacuum leak/misfire. The 2003 with the V8 has the "throttle by wire" system, I'm not sure about the 2003 with V6. If you have throttle by wire, you probably do not have a separate IAC, and then the issue is probably a vacuum leak or misfire.
-Rod
Old Jul 14, 2009 | 12:33 PM
mkarafelis's Avatar
mkarafelis
thanks
Thank you so much. I will make sure I let my mechanic know. I will check with a local dealership to see what the cost for the part is before I do anything else.
Old Jul 28, 2009 | 10:37 AM
osheam's Avatar
osheam
Normally a vacuum leak will result in a code; I would check your air filter first.
Poorboy04
Aug 19, 2012 05:19 AM
2003Navi
Aug 12, 2010 01:29 PM
fjerstadt
Jun 3, 2010 08:12 PM
markley34
2.6, 2.8, 2.9, 4.0 & SOHC 4.0 V6
Dec 20, 2005 09:40 AM
Babcore
Mar 30, 2003 10:51 AM
