4.0 starting rough when warm
Old Dec 19, 2005 | 04:44 PM
markley34's Avatar
markley34
Question 4.0 starting rough when warm
My explorer starts rough when it has been running for any period of time, but when cold it is fine. When I mean rough it revs up and down to the point where it almost stalls or will stall but then if it doesn't stall it will rev back up and down constant until i put the gas down get the truck rpms up for awhile. Any ideas?
Old Dec 20, 2005 | 07:52 AM
PERFORMANCE RED's Avatar
PERFORMANCE RED
Throttle position sensor would be my first guess.
When was the last time you put new plugs, wires, ect... in it? Have you ever given it a good tune up?
How many miles?
Old Dec 20, 2005 | 08:40 AM
markley34's Avatar
markley34
Tune Up
I had a tune up this past fall.
Old Dec 20, 2005 | 09:25 AM
PERFORMANCE RED
how many miles does it have on it now?
Old Dec 20, 2005 | 09:40 AM
mrshorty's Avatar
mrshorty
What year Explorer? Rough warm start is consistent with a leaking fuel pressure regulator diaphragm, but not all Explorers used a fuel pressure regulator. Not sure when Ford started using a returnless system (think it was '97 or '98), but if you have something older, I would check the vacuum line to the FPR for gasoline. Also wouldn't hurt to put a fuel pressure gauge on it to see what the fuel pressure is when it starts rough.
oldmansimek
Jan 20, 2012 05:56 AM
Y block Bill
3.0L V6
Nov 9, 2008 03:33 PM
lowridaz22
31
Jun 9, 2007 10:10 AM
cj091184
1983 - 2012 Ranger & B-Series
Apr 17, 2005 09:46 PM
sporty boy
Jan 7, 2004 05:54 PM
