Rough Shifting, Engine Stalls and Engine Light is on
Old Aug 11, 2010 | 02:57 PM
2003Navi's Avatar
2003Navi
I have a 2003 Navigator that has been great - no issues until now. The truck now is having rough shifting and from time to time stalls out. Now the engine light is on. The owners manual says there is a issue with the gas or water in the tank, but the vehicle runs just fine when I manually shift from 1st to 2nd to drive with the overdrive off. The problem is like driving a manual shift car and shifting to a higher gear before your supposed too. The Navigator has a herky jerky thing going on when the RPM's are at 1.5 to 2.0.
Any idea what is going on?
Old Aug 11, 2010 | 08:37 PM
alloro's Avatar
alloro
The first thing to do is have the vehicle scanned to see what code number turned the light on.
Old Aug 12, 2010 | 01:29 PM
2003Navi's Avatar
2003Navi
Here are the codes I just got:
P0320 Ignition/Dist Enginge Speed Input Circuit Malfunction
P0354 Ignition Coil D Primary/Secondary Circuit Malfunction
P0355 Ignition Coil E Primary/Secondary Circuit Malfunction
P0356 Ignition Coil F Primary/Secondary Circuit Malfunction
P0358 Ignition Coil H Primary/Secondary Circuit Malfunction
P0351 Ignition Coil A Primary/Secondary Circuit Malfunction
P0352 Ignition Coil B Primary/Secondary Circuit Malfunction
P0353 Ignition Coil C Primary/Secondary Circuit Malfunction
P0357 Ignition Coil G Primary/Secondary Circuit Malfunction
Please let me know what you think.
galusham
Jul 15, 2014 08:36 AM
BossTweed
Jul 2, 2013 11:27 AM
Midnite1987
Jul 2, 2012 07:46 PM
kuzindwight
Jan 30, 2009 08:14 PM
JeffD11n
Feb 15, 2004 07:58 PM
