2009 leveling kit
Old Jul 13, 2009 | 09:06 PM
supercrew scott's Avatar
supercrew scott
2009 leveling kit
I just got a 2009 supercrew lariat 4x4 and plan on installing a 2" leveling kit. Any thoughts on the size tire I can install after the kit. I have 275/55 20 on the truck now.
Old Jul 13, 2009 | 10:36 PM
StephonGarnett's Avatar
StephonGarnett
I think you can opt not to change the tires that were already installed. But it is up to you. If you think your truck will look better, then you need to find tires that matches the leveling kit you've bought. You can asked for the assistance of the store where you bought your leveling kit for the tires the fits it.
____________
Stephon Garnett
Old Jul 13, 2009 | 11:40 PM
tcarro2001's Avatar
tcarro2001
From what I have read on other threads, the biggest tire that will fit after the leveling kit without rubbing is a 33 x 12.50 x 20.
Old Jul 14, 2009 | 12:06 PM
04XLTRUNNER's Avatar
04XLTRUNNER
without rubbing is a 33. with little rubbing you can fit a 35. im putting 35's on mine.
Old Jul 19, 2009 | 11:48 AM
supercrew scott
https://www.ford-trucks.com/forums/p...ictureid=12243
I nstalled the 2" leveling kit and put on a set of 275/65 20" goodyear dura trac.
Old Jul 19, 2009 | 11:53 AM
supercrew scott
They are 34x11. No rubs and ride great.
Old Jul 19, 2009 | 12:46 PM
pass-thru's Avatar
pass-thru
How much did it cost you switche them out.....did they give you a good deal to trade int he ones you had?
Old Jul 21, 2009 | 02:20 PM
03Rangerkid's Avatar
03Rangerkid
how much rubbing are we talking about? i got a buddy that will sell me his BFG all-terrains 315/70R17 and want to use those with a leveling kit...
would it be possible?
Old Jul 22, 2009 | 01:12 PM
04XLTRUNNER
rubbing at full turn in reverse is about it. my 05 that with 33s when it was stock. with the level kit it rubbed the lower a arm at full lock. but it was just the side lugs
FordGirl2009
New Member Introductions
Jul 2, 2015 02:18 PM
KLONDON
2009 - 2014 F150
May 25, 2015 03:58 PM
BigDawg5757
2009 - 2014 F150
Feb 24, 2015 10:39 PM
batsonbe
2004 - 2008 F150
15
Apr 18, 2014 10:48 AM
