key Bill
Old Jul 13, 2009 | 02:54 PM
Greyf100's Avatar
Greyf100
key Bill
so we dont hi jack his thread any longer...
its been bored 0.030 Over
3A valve Job
full length header
full 2.5" exhaust w/ magnaflow muffler
hesco TBS
home made intake w/ cone type filter
next on the obtainable list:
Ford Design III, 24LBS injectors from a 4.6l Mustang cobra
and a Performance Distributors: Firewire Ignition system
i ran out of money and patience, i wanted to:
deck the head 0.060
run Chevy 1.94" intake valves
and a clifford cam, valve springs
right now it should be pushing 120-130hp at the flywheel
i was hoping to hit the 200hp mark, naturally aspirated.
Old Jul 13, 2009 | 09:06 PM
6CylBill's Avatar
6CylBill
Whoah, how did you use those Mustang injectors? Do you have a picture of the Jeep this thing belongs to?
Sounds like a real nice build. How much power does that little booger push out from the factory? 130 horse sounds kind of low for a built I4.
You could have just sent me a PM btw! lol
Old Jul 13, 2009 | 09:09 PM
Greyf100's Avatar
Greyf100
oh well....i havent done the injectors yet.
Factory rating was 121Hp.
Thats not me BTW
Greyf100's Avatar
Greyf100
sorry...third pic didnt work
specs:
'98 TJ
5 speed
d30 front w/ lock rite and 4.88's
Ford 8.8 rear (from '98 Explorer) w/ track lok and 4.88's
home built bumpers and steps
PRP suspension seats
5" lift front
4" rear
33" Hankook's
Old Jul 13, 2009 | 09:12 PM
6CylBill's Avatar
6CylBill
All I can is, I want that Jeep. Looks like a lot of fun, that's the kind of stuff I love to do!
I like the idea of building a four banger but have you thought about swapping it for another motor? A V6 would be compact and keep the weight down, and give you an easy 170 horse and 250 foot pounds. You could even build it for more power.
Old Jul 13, 2009 | 09:15 PM
Greyf100's Avatar
Greyf100
if (read when) i blow this motor up, i'll be looking for a 5.3l, L33...sorry guys i know that's saacriligious around these parts....
L33 is aluminum block / heads, makes 300-320HP, and weighs 100lbs less then a 4.3l V-6
as for wheelin' the four make plenty of power, i also tend to keep it high in the rpm range. Factory red line is 5200, factory peak HP is rated at 5250, rev limiter hits @ 6000 RPM.
I've spent the last 6 years or so bouncing the factory motor off the rev limiter, i'm surprised it lasted as long as it did.
Old Jul 13, 2009 | 10:14 PM
6CylBill's Avatar
6CylBill
Ha ha! No joke! That must be one tough booger!!
The 5.3L is a good idea in my book. I didn't realize it was so light though, jeez.
Old Jul 14, 2009 | 07:13 AM
Greyf100's Avatar
Greyf100
theres like 6 different versions of the 5.3l, only the L33 is aluminum...
i thought about a 4.6; moduler, the only problem is they are so wide i dont think it would fit
Old Jul 14, 2009 | 09:18 AM
6CylBill's Avatar
6CylBill
That, and the larger V8 willl produce much better torque; and that's what you need for off roading.
I think a 4-BT Cummins would be a cool idea too. It would be different but match the personality of the Jeep!
Old Jul 14, 2009 | 09:29 AM
Greyf100's Avatar
Greyf100
cummins weighs too much...
i want my build to be "light", would like to be 2900-3000lbs fully loaded....I'm over 4k now
Old Jul 14, 2009 | 09:34 AM
Greyf100's Avatar
Greyf100
heres the old motor and gears... couldnt keep it running
http://vids.myspace.com/index.cfm?fu...deoID=49709118
Old Jul 14, 2009 | 09:53 AM
6CylBill's Avatar
6CylBill
What are your gear ratios now? Looks like a six inch lift would do you wonders!
That's why I suggested the 4-BT, but it's probably not much lighter than the 5.3L and you get a lot more horse with the V8.
Loved the video. You have any more off roading vids?
Old Jul 14, 2009 | 10:03 AM
Greyf100's Avatar
Greyf100
nah, no more vids yet...
actually i will be running 35" tires instead of the 33's
and dropping down to 2.5" springs and a 1-1.25" body lift...
so going up a tire size and lowering it about 1.5-2", from where its at now
Old Jul 14, 2009 | 10:50 AM
jimistephen's Avatar
jimistephen
great looking Jeep.
On a side note the 4bt is like 750 lbs. they are a heavy heavy engine. Like big block chevy heavy.
bruno2
67
Apr 26, 2012 09:51 PM
Hickfied
Jan 9, 2011 02:14 PM
1bad67sbf
47
May 7, 2010 09:08 PM
84f150guy
Sep 7, 2004 11:57 PM
jdhudall
Aug 17, 2004 03:57 AM
