10 easy HP extra?
Old Jul 13, 2009 | 07:18 PM
F-250 restorer's Avatar
F-250 restorer
10 easy HP extra?
A friend has a dyno shop. During a week long dyno rental of a modular engine, the company that was paying the rental found they gained 10hp just by using Mobil 1 oil.
I'm not trying to sell anything. I'm just passing on info.
He also said that the trick way to gain another 10hp is by using a 1" spacer between top of carb and air cleaner.
Old Jul 13, 2009 | 09:30 PM
rockin300's Avatar
rockin300
performance muffler would give you a little bit of hp
Old Jul 13, 2009 | 11:03 PM
optikal illushun's Avatar
optikal illushun
top of the carb and intake? na. carb spacers do work but u need to match it to ur RPM range. the syn oil may work on a modular engine that see's 6,000 rpm+ but on a 300 i doubt it'll see any.
Old Jul 14, 2009 | 12:17 AM
9.ford.5's Avatar
9.ford.5
ive ran penzoil high mileage, mobil 1 full synthetic, and rotella T diesel oil in my 300 since i bought it
the penzoil high mileage and penzoil filter did nothing, the mobil 1 full synthetic with wix filter saw decent improvement, but the biggest difference i saw was going from the mobil 1 to the rotella T diesel oil with a wix filter
so yes mobil 1 full synthetic does help in the 300 but diesel oil works better
Old Jul 14, 2009 | 07:01 AM
Freaksh0w's Avatar
Freaksh0w
Rotella-T is great in my truck, too.
But, want a 10 easy horsepower... use a good flowing intake filter and open up the exhaust. There's ya 10+ hp. By 'open up the exhaust', I mean climb up under it and get creative ;-)
Old Jul 14, 2009 | 10:54 AM
91Bronc300's Avatar
91Bronc300
Do you mean an air horn?
http://www.knfilters.com/Racing/stubstacks.htm
I hear both good and bad about these, and it seems even qualified engine experts disagree on what these things actually get you.
Old Jul 14, 2009 | 11:01 AM
Harte3's Avatar
Harte3
F-250: The only way to determine gains if any for your engine would be dyno pulls. Comparison to the V8 just is not valid.
I've used carb spacers but on a DP manifold with deep ports I don't think there is anything to be gained and I don't use one now. I do use a 3" spacer between the carb and air cleaner. IIRC, Vizard recommends a minimum 3"clearance between the top of the carb and the lid of the air cleaner to improve air flow by reducing turbulence around the top of the carb. Gains, if any would have to be verified with dyno pulls.
Macrobb
21
Mar 14, 2021 09:49 AM
Boport
185
Apr 14, 2017 07:17 AM
parkland
72
Nov 8, 2008 06:56 PM
5 Star Tuning
Modular V10 (6.8l)
17
Sep 15, 2008 02:44 PM
F15099
Aug 8, 2005 08:12 PM
