Sponsored by: Real Truck
Replacement V10
Old Jul 13, 2009 | 01:17 AM
havetwo's Avatar
havetwo
Replacement V10
Well I bought a 2005 F350 8 months ago and took on hollidays pulling my trailer and on the way home blew the motor. The motor had 200 000 km and 5050 running hrs. How hard is it to pull and put a new one in?
Old Jul 13, 2009 | 07:49 AM
Johnny Langton's Avatar
Johnny Langton
Define "blew the motor"-you might only need a repair to the existing engine.
Otherwise-replacement isn't too bad,just time consuming.
JL
Old Jul 13, 2009 | 04:18 PM
havetwo's Avatar
havetwo
I can drive it but it blows black smoke. It didn't like to idle but seemed okay at highway speed. The shop I took it too said that they have never seen spark plugs like that. The check engine light came on and it had a loss of power. I did have o2 senser problems and had it reset before I took it on hollidays. The counter persons last words "if it come back n you'll burn a bit more fuel but you wont blow your motor".
Old Jul 13, 2009 | 07:53 PM
Johnny Langton
Sounds like the truck has an excessive fuel delivery issue to me.
What codes was it showing exactly...the number-not a description.
JL
Old Jul 13, 2009 | 08:21 PM
Fordfanatic4life's Avatar
Fordfanatic4life
does the engine make "mechanical noises" while running ??? like knocking/banging ???
if it actualy turns over and runs without throwing a rod throu the block it might not be that bad of a repair...
i'd get a second estimate before swapping the entire engine out...
Old Jul 13, 2009 | 08:41 PM
jrandol's Avatar
jrandol
You can come pull the V10 outta my 05 if you want. It'll give me a good reason to do a Cummins conversion.
dylansf23
Jul 5, 2014 10:24 AM
Ole' gray
Feb 14, 2012 07:56 PM
1995_f150
Jul 22, 2010 04:22 PM
Adam0331
28
May 17, 2009 09:25 PM
fordfan302
15
Feb 14, 2008 09:29 PM
