1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Replacement V10
Old 07-13-2009, 01:17 AM
havetwo's Avatar
havetwo
havetwo is offline
Replacement V10
Well I bought a 2005 F350 8 months ago and took on hollidays pulling my trailer and on the way home blew the motor. The motor had 200 000 km and 5050 running hrs. How hard is it to pull and put a new one in?
Old 07-13-2009, 07:49 AM
Johnny Langton's Avatar
Johnny Langton
Johnny Langton is offline
Define "blew the motor"-you might only need a repair to the existing engine.
Otherwise-replacement isn't too bad,just time consuming.
JL
Old 07-13-2009, 04:18 PM
havetwo's Avatar
havetwo
havetwo is offline
I can drive it but it blows black smoke. It didn't like to idle but seemed okay at highway speed. The shop I took it too said that they have never seen spark plugs like that. The check engine light came on and it had a loss of power. I did have o2 senser problems and had it reset before I took it on hollidays. The counter persons last words "if it come back n you'll burn a bit more fuel but you wont blow your motor".
Old 07-13-2009, 07:53 PM
Johnny Langton
Sounds like the truck has an excessive fuel delivery issue to me.
What codes was it showing exactly...the number-not a description.
JL
Old 07-13-2009, 08:21 PM
Fordfanatic4life's Avatar
Fordfanatic4life
Fordfanatic4life is offline
does the engine make "mechanical noises" while running ??? like knocking/banging ???
if it actualy turns over and runs without throwing a rod throu the block it might not be that bad of a repair...
i'd get a second estimate before swapping the entire engine out...
Old 07-13-2009, 08:41 PM
jrandol's Avatar
jrandol
jrandol is offline
You can come pull the V10 outta my 05 if you want. It'll give me a good reason to do a Cummins conversion.
dylansf23
07-05-2014 10:24 AM
Ole' gray
02-14-2012 07:56 PM
1995_f150
07-22-2010 04:22 PM
Adam0331
28
05-17-2009 09:25 PM
fordfan302
15
02-14-2008 09:29 PM
Quick Reply: Replacement V10
