Power window ?
Old Jul 12, 2009 | 11:30 PM
dr cabela's Avatar
dr cabela
Power window ?
been hving my driver side window start not working on and off for about a month now
the power locks will work but no windows even if i use the pass side control
checked the fuses today and everything was fine
took the switches out too and made sure they were still connected good
its weird cause one minute they work and the next they dont
then they start working again
could my switch be bad?
99 Eddie bauer 5.4 160,000
Old Jul 13, 2009 | 10:30 AM
alloro's Avatar
alloro
If by this you mean that the passenger also does not work then yes, I would replace the switch.
Old Jul 13, 2009 | 03:15 PM
dr cabela's Avatar
dr cabela
update....switched out the master switch w/ another one......same problem..
what now?
Old Jul 13, 2009 | 03:52 PM
alloro's Avatar
alloro
Next step is to replace the accessory delay relay in the under-dash fuse box.
Old Jul 13, 2009 | 09:22 PM
dr cabela's Avatar
dr cabela
update..............noticed today that it only screws up when the door is shut...... when i open it everything works
still clueless
do i hv a short?
or is the switch that senses my door is shut or open bad?
Old Jul 14, 2009 | 10:02 AM
alloro's Avatar
alloro
I suppose it's possible that you have a break in a wire. As the door moves, so does the wire. Having the door open or closed, by design, does not have any direct affect on the power windows. Since the door position in your case does affect the power windows, I am led to believe a broken wire issue.
ohioexwner
Jan 27, 2015 11:00 PM
teamlx88
Feb 2, 2014 03:34 PM
Steven Matthew
Aug 20, 2012 08:27 AM
2lionel
Oct 11, 2011 09:05 PM
o2civic
2004 - 2008 F150
Oct 21, 2008 11:04 AM
