Power Window Issues
Old Aug 17, 2012 | 08:12 PM
Steven Matthew's Avatar
Steven Matthew
Power Window Issues
Hey,
Today When my workers got back they told me that the windows had stopped working, When I checked it I noticed that on my driver side none of the Buttons Including the Lock and Unlock switch are working, no clicks or whines of motors. Then when I checked the Passenger Side, I noticed the Window switch not working but the Lock/unlock switch was, I changed the fuse for the Window and still the Problem remains. The Window is partly open so I have a bag over it, this happend before and it out of nowhere started working please let me know if you have any advice on this.
Thanks
Steve
1997 F350 7.3l Turbo Diesel Reg Cab 4x4
Old Aug 17, 2012 | 09:23 PM
ReBilld's Avatar
ReBilld
Try taking the switches out of the door panels and take the switches themselves apart and clean all the contacts in them. A buddy of mine had the same problem and this is what fixed his.
Old Aug 17, 2012 | 09:24 PM
ReBilld's Avatar
ReBilld
Oh, and Welcome to FTE!!
Old Aug 17, 2012 | 09:29 PM
95_Dually's Avatar
95_Dually
Welcome to
Old Aug 18, 2012 | 06:35 AM
DIYMechanic's Avatar
DIYMechanic
Welcome Steve! If it were mine, the first thing I would do would be to pull the driver side door panel off and check all the wires at the driver side switch to see if you're even getting power on any of them. The way these things are wired, the power feeds from the driver side switch to the passenger side switch. I believe with the driver side switch unplugged, or not working the passenger side one will not work either. That's why the window lock button can work the way it does. I would second that cleaning the driver side switch up is a good idea too.
Old Aug 18, 2012 | 07:00 AM
91 Dually's Avatar
91 Dually
Check the wires coming into the front of the door (between the fender and door in the rubber boot). They tend to break there from all the opening and closing of the doors.
Old Aug 18, 2012 | 02:08 PM
Steven Matthew
It worked today
I Turned the truck on this morning and the window works, Im guessing something is loose somewhere, Thanks for the welcome and the help.
Old Aug 18, 2012 | 02:45 PM
95_Dually's Avatar
95_Dually
Gotta love those intermittent problems.
Old Aug 20, 2012 | 08:27 AM
Usaman's Avatar
Usaman
Bad Wire
Same issue last year with me, so I called 1-800- BAD WIRE! Sliced open the door hinge boot and found a severed wire. resoldered, taped and all was fine.
Steelguyshaun
Aug 17, 2025 05:10 PM
Eric White
Jun 27, 2012 12:47 PM
Tuxedo Scorpion
6.7L Power Stroke Diesel
19
Apr 18, 2012 08:12 AM
00GT
Apr 27, 2007 11:34 AM
