Toe specs?
Old Jul 11, 2009 | 09:37 PM
fishinfool96's Avatar
fishinfool96
Toe specs?
I'm in need of toe spec's for a 1995 ranger 2wd, 4cl 2.3L. Old tires wore badly on the inside. That leads me to believe that it is toed out too far, Am I correct. I understand how to check the toe but I need to know what measurement is close to being correct. Thanks
Old Jul 11, 2009 | 10:01 PM
g_k50's Avatar
g_k50
0.06 Degrees, plus or minus 0.25 That's from my 1999 Ranger manual.
Old Jul 11, 2009 | 10:20 PM
fishinfool96
Thanks for your time. I dosent say in inches does it? I'll be measuring with a tape measure.
Old Jul 12, 2009 | 12:34 PM
KaoticCreations's Avatar
KaoticCreations
From what I have learned, if your tires are worn badly on the inside, it's usually a sign of too much negative camber. But if the tire treads are "feathered" towards the inside, then you're correct in suspecting the toe specs. Just my 2 cents, but anyways... I don't think Ive ever actually seen alignment specs measured in anything other than degrees. How would one perform an alignment like this without a machine? I mean, when you say you're using a tape measure, what point on the vehicle are you using to measure from? This whole idea is new to me.
Old Jul 14, 2009 | 08:09 AM
lowdownndirty's Avatar
lowdownndirty
are tehy worn smooth or kinda choppy?
smooth would be a camber issue. this happens alot on 97 and older rnagers as they age, due to the springs sagging out.
if its kinda choppy then I would look in to toe.
give me a few day and Ill do a how to get alighn your truck pretty well in the drive way,write up.
unibody62
2009 - 2014 F150
Nov 16, 2014 04:33 PM
Tigress27
Escape & Escape Hybrid
Jan 12, 2014 09:27 AM
jlwpapa
Jul 6, 2013 12:19 PM
68horses
Apr 10, 2009 11:30 PM
