Escape & Escape Hybrid Ford Escape, Ford Escape Hybrid, Mercury Mariner, Mazda Tribute
Understanding Alignment Specs: help needed
Old Jan 11, 2014 | 12:36 PM
Tigress27's Avatar
Tigress27
I have a print out of alignment before measurements and need help understanding some things. Here's the specs:
Left Front
Chamber: -1.3
Caster: 1.5
Toe: .46
Right Front:
Chamber: -1.5
Caster: 1.9
Toe: .55
Total Toe: 1.01
On another website I found some manufacturer specs as follows:
Front Alignment Specs
The caster on the front end can range from +1.1 degrees to +2.1 degrees, but the ideal setting is +1.6 degrees. The camber can ranger from -0.34 degrees to -1.34 degrees, but the ideal setting is -0.84 degrees. The toe-in can range from zero degrees to +0.46 degrees, but the ideal setting is +0.23 degrees.
The questions is does the above specs mean the individual specs for each toe or the total toe?? It's very important for me to know asap. Thank you so much!!
Old Jan 12, 2014 | 12:07 AM
Torky2's Avatar
Torky2
Originally Posted by Tigress27
....... The toe-in can range from zero degrees to +0.46 degrees, but the ideal setting is +0.23 degrees.
Total Toe. I double-checked by looking at my 2010 manual. Total Toe was .23 degrees (unsigned is always positive) +/- .23 degrees. So Total Toe could range from 0.00 degrees up to .46 degrees.
I would always want some toe-in (positive toe) to reduce squirrelyness.
But too much toe-in will wear the tires on the outer side of the tread on both tires.
Wrong-Camber wear can sometimes be confused with toe in/out wear, however, I have seen toe in/out wear to have a feathered look to it. That is, looking at blocks of tread in the same line, the trailing edge of a tread block has a different wear depth than the leading edge of the same tread block. And this difference is repeated around the tire in that tread line.
Over the years, they have reduced the running toe-in in the design of cars to improve gas mileage. Once into the higher MPG ratings, every little bit helps. And running little to no toe-in doesn't cost them anything. We assume that they are using tighter-spec components to make this work, as overall manufacturing specs of mechanical components is a lot tighter than it was in say the 1970s.
Old Jan 12, 2014 | 09:27 AM
Tigress27's Avatar
Tigress27
Thank you so much for answering me!!
hhcobra
Jun 3, 2012 09:38 AM
fishinfool96
1983 - 2012 Ranger & B-Series
Jul 14, 2009 08:09 AM
GoldenDually
2004 - 2008 F150
Jan 28, 2007 05:57 PM
dstruble
Apr 24, 2006 12:15 PM
Phideaux
Aug 23, 2004 08:49 AM
