engine temp to hot?
Old Jul 10, 2009 | 08:33 PM
So-Cal Sancho's Avatar
So-Cal Sancho
engine temp to hot?
Hi guys, after being suspect of a bad dash gauge i installed a aftermarket temp gauge. It was showing 210 deg. Is this too hot for a 180 deg. thermostat installed? I have just changed the radiator, hoses, thermostat, fan clutch. and the water pump. any ideas?
Old Jul 10, 2009 | 08:41 PM
Jermafenser's Avatar
Jermafenser
210 is perfectly normal, despite people's speculation.
Old Jul 10, 2009 | 09:36 PM
EPNCSU2006's Avatar
EPNCSU2006
With a 180° thermostat, my truck ran anywhere from 180 in the winter to close to between 195 and 200 in the summer. Now I have a 192° thermostat and the temperature stays right around 190-195. It won't really hurt anything running at 210, but I would think that the operating temperature with a 180° thermostat would be a good bit closer to 180 than 210.
Old Jul 10, 2009 | 09:52 PM
fordman1090's Avatar
fordman1090
210 is perfectly normal. Especially in the summer. Many people believe that a 180 t-stat should keep the engine at 180, but in reality it doesn't start opening until 180, and opens more and more as the engine heats up.
Old Jul 10, 2009 | 10:45 PM
So-Cal Sancho
i always thought that the 180 deg.t stat keeps it at 180. but i assumed that it would get higher with a load. I also used a infrared temp gun on the upper hose at the water neck and that showed 180 deg. while the gauge showed 190 deg. kinda weird to me but as long as theirs no steam from the radiator it's all good.
Old Jul 10, 2009 | 11:33 PM
HrdDrv's Avatar
HrdDrv
210 is cool, so to speak. (OK in laymen's terms.)
A thermstadts temp rating is when it's supposed to open. Go with the trucks OEM rating for the engine, keep your rad clear of debris, and check the hoses and coolant (Antifreeze/water mix) ratio correct. Also check your cooling fan for proper operation.
Old Jul 11, 2009 | 12:03 AM
So-Cal Sancho
here's another question, when does the top radiator hose get hot, and hard? I can squeeze mine shut. does that mean the t-stat is closed? I did notice before that the hose was hard and hot.
Old Jul 11, 2009 | 06:32 AM
EPNCSU2006's Avatar
EPNCSU2006
The thermostat's rated temperature is where it should regulate the coolant temperature, within a few degrees, unless the cooling system cannot reject enough heat to keep it that low. Heat rejection increases with temperature delta, so the cooling system temperature rises until the heat rejection matches the heat input from the engine.
The cooling system should build pressure as the engine builds temperature, up to the relief pressure on the radiator cap. If it is not building pressure, check the radiator cap and the tube that connects to the overflow tank. Even if the thermostat was not opening, the system should build pressure.
Old Jul 11, 2009 | 12:04 PM
Old93junk's Avatar
Old93junk
210 is fine, nothing to worry about.........................This is why new vehicles have temp guages that just say,.......Cold - normal - Hot......If they actually had numbers on them telling how hot they really run, most people would **** themselves!
Old Jul 11, 2009 | 01:17 PM
HrdDrv's Avatar
HrdDrv
Not to hijack the thread, but keeping with the theme, there is a recipe book pertaining to the art of 'manifold cooking', where-as, you wrap food goodies in tinfoil, place it on the engine and drive for a period of time. When you get to your destination, dinner is done...
I know, I know... Please do the research. While on an aircraft-carrier, I kept my lunch/dinner hot by placing it in the frame of the main engine.
Your coolant temp may be 210-ish, (regulated), but the underhood temps can go beyond that.
Old Jul 11, 2009 | 01:41 PM
Jeff Dodson's Avatar
Jeff Dodson
Besides the oil is not as effective unless the temp is at or around 200, I read on another site where extensive study has been done, That is the temp the meatl actually absorbes the oils molecules
obscurity
Jun 10, 2013 10:32 AM
So-Cal Sancho
31
Oct 29, 2009 06:02 PM
So-Cal Sancho
Jul 15, 2009 09:28 AM
CF-DRG
Apr 22, 2006 09:36 PM
monsterbaby
Apr 16, 2006 01:18 PM
