temp too hot?
Old Jul 10, 2009 | 08:18 PM
So-Cal Sancho's Avatar
So-Cal Sancho
temp too hot?
Hi guys, after being suspect of a bad dash gauge i installed a aftermarket temp gauge. It was showing 210 deg. Is this too hot for a 180 deg. thermostat installed? I have just changed the radiator, hoses, thermostat, fan clutch. and the water pump. any ideas?
Old Jul 10, 2009 | 09:05 PM
dstig1's Avatar
dstig1
The 180 on the Tstat just means that is the temp it opens at. If you are in a hot area (So. Cal??), then 210 is not real surprising. That's partly why the system is pressurized - to keep the water/glycol from boiling too early. It also helps if you have a 50/50 mix of glycol and water for best heat transfer.
You are also assuming the aftermarket gage is accurate...
-Dave
Old Jul 11, 2009 | 06:14 AM
projectSHO89's Avatar
projectSHO89
195-210 is pretty normal.
Old Jul 11, 2009 | 04:23 PM
2000Ford2000's Avatar
2000Ford2000
Ya, you just changed a lot of stuff for nothing.
Old Jul 14, 2009 | 11:55 PM
So-Cal Sancho
yeah think i did change it for nothing, got some nice shiny new stuff in there though.
Old Jul 15, 2009 | 09:28 AM
Rusty_S's Avatar
Rusty_S
A 180* thermo starts to open up at 180* but usually isnt fully open till around 200* and by then your temp could run on up to 210* - 220* before the flow of cooling drops the temp back down to 180* or below.
BGF100
Mar 1, 2017 08:59 PM
joegeds
Aug 11, 2016 08:44 AM
chrislynn5
May 1, 2016 07:04 PM
mdula
31
Dec 10, 2010 10:29 AM
So-Cal Sancho
31
Oct 29, 2009 06:02 PM
