Sponsored by: Real Truck
need broken 4x4 shift motor
Old Jul 10, 2009 | 08:25 PM
rockcrawler_101's Avatar
rockcrawler_101
Im going to be trying to convert my electric shift t case over to manual shift. But i need a broken shifter motor because im pretty sure mine still works. Thanks.
Old Jul 10, 2009 | 11:23 PM
06silvercrew's Avatar
06silvercrew
Ive got all the parts to do it, just havent had time to do it. I have a bad motor.
Old Jul 10, 2009 | 11:28 PM
rockcrawler_101
i mainly need the round shifter end thats on the motor so i can weld a arm to it. Then im going to use some hyme joints and build the shifter. probably do a bunch of short welds to the arm and t case round part so not to kill the seal
Old Jul 11, 2009 | 04:54 PM
06silvercrew
LOL Damn great minds think alike. Although Im using stock shifter and part of stock linkage.
Old Sep 6, 2012 | 08:13 PM
st8yd's Avatar
st8yd
So how did this go?
Old Sep 6, 2012 | 11:01 PM
rockcrawler_101
Worked great been using it for a long time now. If you search under my name you can find a build on it.
Old Sep 7, 2012 | 06:40 AM
st8yd's Avatar
st8yd
Thanks, I was more just curious if you went thru with it.
My hubs stopped working a few years ago, and have since been changed to Warn and I tolerate having to manually switch them. But next time they go out I will probably fix them right with the vacuum.
But I really don't want the shifter on the floor, I've contemplated maybe a push/pull type cable as it really doesn't take much to rotate it in. But I'm lazy and like the convenience of the esof.
bettyford93
Dec 2, 2014 06:54 AM
1986F-150
Feb 21, 2012 06:42 PM
Nickiboy
Oct 30, 2009 01:41 PM
ncranchero
1997 - 2003 F150
May 12, 2007 10:39 PM
philmo418
Sep 1, 2005 08:50 PM
