Another Push Button 4X4 Question
Old Sep 17, 2004 | 12:31 PM
philmo418's Avatar
philmo418
Question Another Push Button 4X4 Question
Hi,
I have a 1992 Full Size Bronco EB. The other day while I was doing the monthly test and exercise of the TC shift motor the system went dark and left me in FWH. No 4X4 lights, no clicking noises nothing. I removed the motor and gave it a bang or two, tried to test the TC electronic shift module but the self test button was broken. I then metered all the connections and found everything had power, the push buttons work and the system thinks it is in FWL the selector on the TC points to FWH. All this leads me to three questions.
1. I need this back on the road ASAP. Can I remove the motor, shift to manually to TWH and drive it until I get my parts?
2. Will the Hubs disengage after the manual shift to TWH and rolling backward as normal?
3. Motor or Control Module?
Philmo.
Old Sep 21, 2004 | 08:44 PM
racsan's Avatar
racsan
yes, you can manually turn the transfer case (with the motor removed ) to 2h and back up and the hubs should unlock and the truck be in 2wd. i would suspect the control module to have problems since you dont hear any clicking noises when pushing buttons.
Old Sep 1, 2005 | 08:50 PM
KENS94F1504*4's Avatar
KENS94F1504*4
phil.........can you tell me the remedy??? thanx
jlb911c
1978 - 1996 Big Bronco
Feb 23, 2015 08:14 AM
427mike
Dec 28, 2014 01:36 PM
Dodge-My-Cummins
Aug 1, 2012 06:27 PM
BroncShane
Feb 23, 2004 02:11 PM
RSOsborne
1983 - 2012 Ranger & B-Series
Mar 25, 2002 11:47 AM
