How to shift into 4wd manually linkage broken
Received 3,090 Likes
on
on
yup, chock the wheels so the truck does not roll over you. you will need to put the trans in neutral. i don't trust parking brakes if i have to drawl under the truck.
and yes, use the wrench to move the shaft coming out of the transfer case.
when you get under the truck and remove the linkage from the t-case you will see on the shaft there are 2 flat spots on each side of the shaft.
put the wrench on the flat spots and then move the lever.
if you start from 2 wheel drive, one click will put you in 4 high. two clicks will put you in neutral, three clicks will put you in 4 low.
on
Okay so I am having a bit of trouble here I can't seem to get the shift linkage off of the arm in connects to, and goes to another arm to the transfer case. I tried to pry it off using a screwdriver like a bar, and some WD40 but no luck.. is that the right piece I am trying to pry off? I tried to shift it under the truck with the linkage on, seemed to "click" but no 4x4 light came on. Probably just the linkage hitting up against the trans
Yeah I will have to try harder obviously, like you said bashby I don't want to break any else as I plan on getting the linkage in the future... I'm also wondering how it should shift coming out of the Tcase, I'm wondering if it kind of rotates or should I be able to pull/push it horizontally? I live in an area with lots of hills and the town doesn't plow as much as they could so 4wd is essential here. I am going to get it inspected today and luckily the roads aren't bad now considering the massive storm we got last week.
Sean_Memphis
20
03-08-2015 03:17 PM
jackndelphine
03-31-2009 06:20 PM
BombThreat
01-07-2009 09:50 AM
175Ranger
02-11-2004 05:55 PM
