Sponsored by: Kumho
when right is wrong
Old Jul 10, 2009 | 07:53 PM
wilbilly216's Avatar
wilbilly216
when right is wrong
i am having a problem with my 94 f 150. once in a while, my truck will start to pull to the right. sometimes when i am coming out of a right hand turn it wants to stay right, or when i am on the highway and hit a bump or a dip and it starts pulling to the right. after a minute it straightens out. if i crank the wheel to the left it straightens out until the next sudden pull. i jacked it up and can't find anything loose. please help
Old Jul 10, 2009 | 09:38 PM
mark a.'s Avatar
mark a.
If it's a 4x4 it might have a froze up axle u joint.
Old Jul 11, 2009 | 01:11 AM
Ford_Six's Avatar
Ford_Six
Ball joints, axle universal, pivot or radius arm bushings, tie rod ends, and the steering box itself can all cause this sort of problem.
Old Jul 12, 2009 | 04:44 PM
wilbilly216
Thanks for the suggestions. Aside from jacking up the wheel that I believe is giving me the problem and prying on everything, how do I narrow down the problem.
Old Jul 12, 2009 | 05:39 PM
mark a.'s Avatar
mark a.
Axle ujoint, Turn the wheels all the way in either direction. Reach in to the axle u joint and try to turn it, if it doesn't turn free then it's bad. Ball joints, jack one side up enough to put a long bar under it. Work it up & down to see if there is any play in it. If you don't find anything then jack it up set it on stands and work the steering back & fourth & see if you can feel/see it binding anywhere.
Old Jul 12, 2009 | 06:47 PM
nathan19's Avatar
nathan19
This... could be any of those things. Best of luck figuring it all out bro
Old Jul 14, 2009 | 04:28 PM
wilbilly216
Thank you Mark. I believe I have found the problem and it is in fact the axel ujoint. do you think it would be wise to go ahead and replace them both and do you have any tips on how to replace them? I am an ammature mechanic at best just learning as i go. thanks again.
The Terrible Blob
13
Mar 28, 2014 05:56 PM
DieselJr
Jun 3, 2012 09:13 PM
bgbully
Nov 17, 2010 02:55 PM
F250_
Paint & Bodywork
Mar 4, 2007 10:28 PM
eclectix
Jul 30, 2003 12:05 PM
