Why does only one wheel spin when doing a burn out ?
Old Jul 10, 2009 | 06:54 PM
shade111's Avatar
shade111
Got's a question about my f-350, when I was leaving a buddy's house the other night , He was busting my b--l's about my 7.3 so I lit the beast up and left a one leg stand about 75 yards. Why didn't both wheels spin ?
Old Jul 10, 2009 | 07:08 PM
That_Guy's Avatar
That_Guy
Do you have a limited slip? and even if you do the clutch packs inside could be worn out. Sometimes if you throw to much power at the wheels at once the limited slip wont grab..
Old Jul 10, 2009 | 07:11 PM
schlepprock250's Avatar
schlepprock250
Once I get it goin',the other side catches and kicks in pretty quick.
Old Jul 10, 2009 | 07:27 PM
Izzy351's Avatar
Izzy351
If it is LS, there could be too much friction modifier in there. Look at the sticker in the driver's door jamb. Under "AXLE" (if it's a 3.73) it'll say "31" or "C1". C1 = LS, 31 = open diff.
If you have 4.10s, it'll say C2 or 32.
Old Jul 10, 2009 | 08:41 PM
shade111's Avatar
shade111
Do you think the axle juice is worn down, because the truck before spun both tires. I don't make a habbit of doing burn outs all of the time but it's been awhile since I have done one. The truck has 116000 on her and I have not changed the axle juice in a long time ?
Old Jul 10, 2009 | 09:30 PM
WA.Ranger's Avatar
WA.Ranger
I have a stock rearend with LS and 176,000 miles on it, and it will burn both?
Old Jul 10, 2009 | 10:11 PM
Izzy351's Avatar
Izzy351
You can try changing the lube. Try to get 75W-140 without any friction modifier and add your own 2 oz. at a time until it doesn't chatter anymore.
I just changed mine last month, but I put in Royal Purple with the FM already in it. Need to do a burn out to make sure the clutches are working right. Think a cop will buy that if I get busted??
EDIT: If you do decide to change the fluid, look into the '08 cover (I'm assuming your 350 is not a dually). Here's what mine looks like:
Old Jul 11, 2009 | 06:36 AM
shade111's Avatar
shade111
I think I will try changing it, that is a cool looking cover !!
Old Jul 11, 2009 | 02:20 PM
Crete's Avatar
Crete
What does a "D1" indicate?
Old Jul 11, 2009 | 02:46 PM
Izzy351's Avatar
Izzy351
3.73 LS. What the difference between C1 & D1 is, I don't know. Here's where I got the info:
http://www.drivetrain.com/parts_cata...s_it_posi.html
Old Jul 11, 2009 | 03:35 PM
PowerstrokeJunkie's Avatar
PowerstrokeJunkie
You my friend need a Detroit Truetrac
Old Jul 11, 2009 | 03:50 PM
shade111's Avatar
shade111
Mine say's RC:11 and I can't find it listed on the drive train site ? Weird ?
Old Jul 11, 2009 | 03:57 PM
redfire42's Avatar
redfire42
Does that cover come with bolts any everything you need? Plus where did ya get it, looks nice and shinny under there
Old Jul 11, 2009 | 05:52 PM
WA.Ranger's Avatar
WA.Ranger
Looks like he got it ALL from Target!?
Cover comes by itself. You'll want to get SS cap-head bolts for the install. I'll see if I can find the size.
Old Jul 11, 2009 | 05:56 PM
WA.Ranger's Avatar
WA.Ranger
Read post #1 and #7
https://www.ford-trucks.com/forums/8...iff-cover.html
The only thing I did different was use cap-head bolts instead of hex head, makes no differance.
