Power Mirror problem
Old Jul 25, 2009 | 02:24 AM
ChunderDownUnder's Avatar
ChunderDownUnder
Thx guys I really appreciate the offer. And you are right even with the freight/exchange rate I can get thing from the States about 30% cheaper. ATM Clay has been helping me out with heaps. I have $1500 worth of gear about to be shipped. I have to settle down for a while after that cause HQ is bustn my ***** about the money Im spending on my truck . I have PMS real bad
Old Jul 27, 2009 | 10:15 AM
F250_'s Avatar
F250_
Originally Posted by F350-6
Did you happen to snap a picture of the inside of the switch?
Chris:
I took several pictures of the inside of my switch this weekend. I'll have to get them downloaded off my son's camera onto my laptop, and then I'll post them up.
Esentially, there are three multi-level metallic switches that are operated based upon which direction the position toggle switch is rocked. I ended up raising my contact points too high on all three positions and blew my fuse when I plugged the switch back in. For now, I've just purchased and installed a new switch ($24 from my local dealer, or $17 plus S&H from Ed at Y2K). I'm going to take some evening time this week to play with the contact positions some more, probably blow a couple more fuses in the process, and eventually get it fixed.
Having gone through the first attempt and seen it turn out the way it did, I believe the problem I was having was that one of the three contact points was too HIGH and needed to be pushed back down a bit. Instead, what I did was to push the others up just as high as that third one, and I think that's what blew the fuse... sending power to everything at once!
kyle.good
2004 - 2008 F150
Feb 9, 2012 06:27 AM
Curt's05
Dec 5, 2011 01:30 PM
97 HD
2004 - 2008 F150
Aug 13, 2009 02:34 PM
TimTheGuitarMan
Jun 21, 2006 03:44 AM
mooncruiser
Aug 27, 2005 01:57 AM
