Tranny circulation issues
Old Jul 9, 2009 | 12:35 AM
moarkmike's Avatar
moarkmike
I have a F250 that I haul a 5th wheel with. I have been battleing this issue for a while now and it is gotten to where I cannot convince my wife to go too far from home.
I had my 97 transmission rebuilt a couple of years ago after we were stranded on the road with our dog and 2 small kids. When I had it rebuilt I included a triple clutch TC and a towing shift kit, I also included a MagnaHytec pan and external filter along with a temp guage. Oh yeah and an additional cooler. Every since then I have had a cooling issue that comes and goes. Sometimes the fluid is circulateing fine and the temp will stay around 160 f and then it will just stop getting to the Aux cooler. Does anyone have any thoughts on this? It is driving me crazy! <!-- / message --><!-- BEGIN TEMPLATE: ad_showthread_firstpost_sig --><!-- END TEMPLATE: ad_showthread_firstpost_sig -->
<!-- controls -->
Old Jul 9, 2009 | 07:49 AM
l-m tech's Avatar
l-m tech
sounds like the thermostat in the bypass line on the side of the trans is giving u issues
Old Jul 9, 2009 | 10:00 AM
moarkmike's Avatar
moarkmike
Thanks I-M tech,
Is this something that is easy to get to or replace?
Old Jul 9, 2009 | 05:03 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
There is no thermostat in the bypass line. There is a pressure relief valve, but no thermostat.
Old Jul 10, 2009 | 12:07 PM
moarkmike's Avatar
moarkmike
is this the one with the ball and spring? More like a check valve?
Old Jul 10, 2009 | 02:49 PM
Mark Kovalsky
Yes, it's a ball and spring. It is not a check valve and it is not a thermostat. It is a pressure relief valve. If the coolers are plugged the pressure gets high and moves the ball off of the seat, allowing flow to the rear of the trans.
Old Jul 10, 2009 | 05:29 PM
l-m tech's Avatar
l-m tech
I think u stated it wasnt a thermostat already,make that 3 times
Old Jul 10, 2009 | 09:44 PM
Mark Kovalsky
That was only two times. It's not a thermostat. That makes three!
jabro
Jan 19, 2016 03:55 AM
norcalex
26
Jun 4, 2015 12:09 PM
cecilt
Jan 9, 2010 06:20 PM
Warhippie
Jun 14, 2009 06:58 AM
srkr
May 25, 2009 07:04 PM
