AOD identification
Old Jul 10, 2009 | 07:29 PM
88blackgt's Avatar
88blackgt
AOD identification
Plan on doing a C4 to AOD swap but am unsure which variation of AOD would make for the easiest swap. Its going into a 79 F100 2wd.
Are there any casting numbers or specific features to look for?
Thanks
Old Jul 10, 2009 | 08:40 PM
Sportruk's Avatar
Sportruk
The only upgrage I know of is the slight change in '85. They improved the case strength and a couple other internal improvements. You can tell by the 5 bars on the top of the case, while the pre'85 had only 3 bars.
The truck AOD is a bit stronger with more discs and has a 1" longer tailstock housing than the car AOD.
Shift linkage should work from the C4. It's been a lot of years since I swap C4 to AOD and I don't remeber if I had to change anything.
All carbed engines used a solid linkage for the TV control, while EFI used a cable. The cable works better. Get a Lokar TV cable kit. It will save a lot of headaches.
Old Jul 10, 2009 | 09:09 PM
Conanski's Avatar
Conanski
I'll add that there were various upgrades made to the internal parts over the years so a later model tranny will be stronger than an earlier models... unless you find one rebuilt with upgrades of course.
Old Jul 10, 2009 | 09:24 PM
Sportruk's Avatar
Sportruk
You mean something like from your local tranny guru, Lentech.
Old Jul 10, 2009 | 11:09 PM
85e150's Avatar
85e150
The performance sites say they use '88-'93 cores, and to pick one from behind a V8, car or truck, or a six in a truck.
http://www.transmissioncenter.net/AOD.htm
http://www.becontrols.com/products/aodcat.htm
http://ckperformance.com/ford_aod.html
http://www.tciauto.com/Products/Ford/ford_aod.asp
The short version of the performance trans is AOD-E and/or 4R70W parts in the AOD case, along with certain other magic.
Good luck with it.
Old Jul 11, 2009 | 01:30 AM
88blackgt's Avatar
88blackgt
Sounds good thanks very much for the info
Tony Ricci
Mar 11, 2017 10:00 AM
wtroger
Mar 4, 2016 01:22 AM
A73F100
Jan 14, 2014 07:50 PM
72 Bronco
1966 - 1977 Early Broncos
May 17, 2006 08:57 AM
witdog2020
Jan 9, 2006 07:47 AM
