Fuel problem!!
Old Jul 8, 2009 | 08:47 PM
K20maniac's Avatar
K20maniac
Fuel problem!!
Guys I have a problem that is driving me nuts!! I changed the fuel filters on the truck and I think the truck may have gotten air in the system as I was told that wouldn't let the car start... How could I drain the system of Air. Please share your knowledge guys I desperately need your help!!!
Old Jul 8, 2009 | 09:01 PM
Kep4's Avatar
Kep4
Jäger
Tell us the procedure you used to change the filters and some info on the truck. What brand fuel filters did you use?
Old Jul 8, 2009 | 09:04 PM
william_04_x's Avatar
william_04_x
turn the key to on/engine off and listen for the fuel pump..leave it on for a few seconds.. turn the key off.. repeat this a few/several times and the system should be bled..
Old Jul 8, 2009 | 09:23 PM
K20maniac's Avatar
K20maniac
I used to ones that they sell at ford I think they're called motorcraft... I just unscrewed
the caps took out the old filters and put in the new ones... But for some reason the car won't start..
Old Jul 8, 2009 | 09:34 PM
bismic's Avatar
bismic
Did you snap the filter into the cap and then screw it in? Did you use new o-rings? Did yoyu lubricate the o-rings w/ oil? Are you sure you are not cross threaded? Did you use a torque wrench on the caps or just tighten "by feel"?
Old Jul 8, 2009 | 09:41 PM
K20maniac's Avatar
K20maniac
Filter was snapped onto the cap, new o rings were used, did not find lubrication necessary... Tightened by feel,,, is there a necessary torquing specification? And what do you mean by cross threaded?
Old Jul 8, 2009 | 09:51 PM
K20maniac's Avatar
K20maniac
gyuugdddrtygg
Old Jul 8, 2009 | 09:59 PM
bismic's Avatar
bismic
Oil lubrictaion is always a good idea. It keeps the o-ring from getting dried out from the fuel and it helps it stay in place when the filter is installed (they can "kink" although it is rare).
The filter packaging includes instructions that have the torque specs. How necessary it is, I do not know for sure. However, I have heard of folks cracking the plastic cap from over tightening the cap.
Lots of folks have found it awkward to get their hand (and tools) on the HFCM filter cap. If it is not started correctly when screwing the cap on, the metal threads of the housing can be off set from the threads of the plastic cap. This can damage the cap threads when trying to tighten the cap down. The cap will then eventually leak.
Old Jul 8, 2009 | 10:09 PM
Kep4's Avatar
Kep4
Jäger
gyuugdddrtygg
Something was telling me that's the type of truck you have!!!
Old Jul 9, 2009 | 07:16 AM
K20maniac's Avatar
K20maniac
No that's me just describing how the truck sounds while trying to crank... Lol
Old Jul 9, 2009 | 08:03 AM
69cj's Avatar
69cj
Side Note; I still don't know what type or year truck he has!
Old Jul 9, 2009 | 10:08 AM
BPofMD's Avatar
BPofMD
Veteran: Navy
I would imagine that it's a 6.0 diesel seeing how he's found the 03-07 thread!
Old Jul 9, 2009 | 10:13 AM
K20maniac's Avatar
K20maniac
Sorry about that Its an 06 6.0 f250 lariat..
Old Jul 9, 2009 | 10:51 AM
cartmanea's Avatar
cartmanea
I quit using a torque wrench on the fuel and oil caps, it would click before the cap was seated completely because the o-ring was too tight. I just tighten until the cap seats and give it a little more snug.
Old Jul 9, 2009 | 01:51 PM
K20maniac's Avatar
K20maniac
Is there anything else you do after that ?? Or do you guys just swap out the filters and that's it..?
