O/D Light Flashed, reset...No Code??
Old Jul 8, 2009 | 02:10 PM
Budget Racing's Avatar
Budget Racing
I went to the local stealership and they pulled codes from my 2001 F250 (w/ DP tuner, BTS VB, muffler delete) after my foot got a little heavy while pulling my 12K-15Klbs 36' fiver. I usually pull out real slow and get everything warmed up good but I got a little to enthusiastic and had the O/D light blinking. Stopped and check the fluid...OK and went home. After restart light was gone...drove the truck yesterday and everything seemed fine but stopped and got the code pulled anyway and they said there wasn't one. Is it possible that the O/D flashed but no code was set?
Old Jul 8, 2009 | 02:26 PM
RedBoat's Avatar
RedBoat
Rather Be Floatin
Budget, usually the OD blinks when the VSS on the rear pumpkin is bad, but if you dont have a code and everything is working ok then ??? Hopefully someone can come along with more info than me.
Old Jul 8, 2009 | 02:33 PM
miller_feed's Avatar
miller_feed
Hook it, I'll pull it.
If the OD light was blinking, there should be a code. Who did you use to read for codes?
I sure hope you have a set of gauges. How hot did you get the trans?
Old Jul 9, 2009 | 06:34 AM
Budget Racing
Yes, I do have gauges...I never saw the temp gauge over 160 but I guess it could of spiked.
Old Jul 9, 2009 | 04:09 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
There are about 50 different things that can flash the OD light. Each one is supposed to store a code in memory. The ONLY way to know what's wrong is to read the codes. I see you did and they didn't find any.
Was it flashing at a steady rate? It's supposed to flash 1/2 second on, 1/2 second off. If it is anything different from that it could be a damaged wire to the OD switch.
Old Jul 9, 2009 | 08:30 PM
Budget Racing
Yes, it was flashing at a steady rate. I am going to another dealer in the next town next week and I'll see what they come up with. I'm towing this weekend (not far 60 miles round trip) so we'll see how it goes...I'll have to take it easy (rats). Thanks for all the info...will update soon.
Old Jul 9, 2009 | 08:57 PM
miller_feed
Let us know what you find. You have the best guy on here that can help you (Mark).
snaponprofile
29
Apr 17, 2011 01:27 PM
cjben
Nov 29, 2009 01:33 PM
cjben
Nov 27, 2009 04:04 PM
martinjose
Oct 26, 2006 02:03 PM
f150xlt96
Apr 5, 2003 10:30 AM
