afe vs 6637
Old Jul 7, 2009 | 11:16 PM
az old school's Avatar
az old school
afe vs 6637
ok az.scarcrow and i installed the 6637,and ran better then stock style then az.scarcrow read a write up on the afe 24-91042 5 layer filter inverted we found them on internet for $ 100.00 each shipped to front door,well they came in put mine on and because my truck is a 99 it got the air from fender no problem because my air comp for my DUAL train horns sit perfect in that space,i also cut out the fiberglass behind the grill next to the after cooler to allow more cold air to enter in engine compartment both sides {pics are below} after doing that it dropped engine temp by 12-16 degress it runs no matter pulling or not at 185-200 max engine temp,i installed afe today and it made my egt,s drop 50 degress,with no baffle in between filter and engine,so in my words spending money on cold air intakes is a big waste of money
Old Jul 8, 2009 | 09:31 PM
Az.scarecrow's Avatar
Az.scarecrow
I got to give credit where credit is due - bdrummonds
Thanks for the thead on the AFE - https://www.ford-trucks.com/forums/7...fe-6637-a.html
Here is mine
Old Jul 8, 2009 | 09:45 PM
4inchlovin's Avatar
4inchlovin
Cutting out the header panel behind the grill is commonly known as the ZOODAD mod. so you can add that to your sig when you get a chance... Nice work guys!
Old Jul 9, 2009 | 08:09 PM
az old school
6637 vs afe
thanks for info
Old Jul 9, 2009 | 09:52 PM
aldridgec's Avatar
aldridgec
Just be careful, too much air around (instead of through) the coolers could be bad.
Old Jul 10, 2009 | 11:31 PM
az old school
i put a flow meter in engine compartment before and after 80% increase,witch dropped engine temp and more cool air{witch right now in az doesnt mean cool air its allways hot 115 air lol}
Midwest Dually
General Diesel Discussion
310
Feb 18, 2024 03:30 PM
scarty111
Nov 26, 2016 06:08 PM
ROBBINthaHOOD
Oct 4, 2016 06:23 PM
SteveBricks
S. California Chapter
21
Sep 15, 2015 10:55 AM
'94IDITurbo7.3
22
Jul 18, 2012 07:02 PM
